Change your front differential fluid!
Took some sharp bends on the highway at higher speeds (70mph or about 120km/h) and the noise doesn't change. So I assume it isn't wheel bearings because the sound is constant based on speed of the truck, not on which wheel has less or more weight on it.
So figured it is the front or rear differential. No idea which one.
Have read the horror stories of front differentials failing on these trucks and needing all new bearings. Apparently the bearings fail and when you drain the diff you get metal shavings (or even silver coloured fluid with metal bits suspended in the fluid)
I figured I'd drain/fill the front first, drive the truck, then do the back. That would give me an idea of which one is causing the problem.
VERY easy to do in these trucks. Raise the truck with Airmatic (easy!) or jack it up (harder). Remember Airmatic only lifts the truck 4" so you can even get some ramps or possibly two flat 2x8 boards under each of the four tires and you should be good.
Crawl under the truck, remove the belly pan cover (the rearward one, not the front one) and open the fill plug (first!) then the drain plug.
I measured my fluid and it was approx 950ml. The capacity is 1.1L (1100ml). So it was low but I figured not enough to make a difference. Fluid was the color of Coca-Cola and new is the colour of maple syrup, so it looked old. Smelled worse than the new fluid (not necessarily burnt, but more of a "completely worn out" smell if that makes sense).
NO metal particles at all. Just really dirty fluid.
Use Febi fluid.. it's called "Hydraulic-Getreibeol" (Hydraulic Gear Oil in English). Much cheaper than the MB stuff and meets all the proper specifications.
You need 2 liters because capacity is 1.1L. I didn't measure but definitely used more than that. I'd estimate that I put back in somewhere between 1200-1350ml.
So the differential has about 250-400ml more fluid now than before.
Howling is GONE! Glad I didn't drive further before changing this fluid.
There is NO service interval but for the cheap cost of the fluid, change yours NOW unless you know exactly when it was done before. I'll be doing the rear this weekend too.
Handy tip: don't use those 'soap dispenser' type pumps. They don't fit the bottles and I counted 15-16 pumps to just move 100ml of fluid. So I would have to pump 200x which sucks when you are under the car
Go to Princess Auto (Canada, $10) or Harbor Freight (US, $6) and buy an oil suction gun. The plastic version is fine. Capacity is just under 1/2 liter.
Filled it and pumped into the differential 3x and I was done. Dribbled out, put the plug back in, and all is good.
30 min job includes a quick test drive, removing/installing belly pans, etc.
The first time you do it may take longer (and if you have to jack up the truck that takes time). But Airmatic and if I have to go do both, I can probably do it in an hour total for front/back.
Check your Transfer case to make sure you got oil in there, drained mine todaygot very little oil outand suspecting it was my humming noise. Felt like wheel bearing. Will refill next 2 days and find out if it was my problem, if i am lucky that low oil didnt mess up my transfer case
i guess it was right. Didnt drive it yet to feel if noise went away. Will let you know in next few days. But now i know that both diffs and transfer case got fresh fluid. Sorry for false alarm, very surprised that it takes only half of quart
Made me think that humming noise coming from center bearing on the driveshaft. Unless front diff or wheel bearings have to be under load to make noise.
Very annoyed with that sound, feels like i am driving a KIA not a MB.
With no vehicles near you, and firmly in control of the vehicle, steer left and right inside your lane gradually but firmly, several times. If you hear changes in the humming sound, a wheel bearing or bearings can be the culprit. The loudest noise will come from the bearing which has the heaviest loading, which is on the opposite site to which you are steering. Very easy.
Another wheel bearing test for more advanced failures (worn bearings) is to notice if the sound changes with vehicle speed. For example, decelerate with no brakes applied (coast) and listen to the sound. If the sound changes while decelerating with no brakes on a straight, smooth road, wheel bearings are suspect.
Drivetrain (e.g. center bearing) humming is very easy to diagnose. Drive the car on a straight, smooth road at the speed which the sound is loudest. Do not use cruse control, but rather keep your foot steadily on the accelerator pedal. Notice the noise intently. Then lift your foot off the accelerator pedal, and decelerate a few mph/kmh. Then put your foot back on the accelerator and accelerate to the original speed, where the sound was loudest. This is called tipping into and out of the accelerator. If the sound changes during tip in/out, you have worn drivetrain component(s), likely in the main propshaft.
After you do these tests, please report back. There are other drivetrain tests to dig deeper into which shaft and which joint(s) are the problem(s).
M-B indeed does not specify GL/GLS/ML/GLE axle or transfer case oil change intervals, although oil change is required for high mileage operation.
I think 100,000 miles/160,000 kms is a good interval for this. This is based on 40 years of motoring and 1 million miles of vehicle operating combined experience.
Strangely, M-B does not recommend replacing the poly-v belt. To me this is another good 100k mile service item.
M-B is one of the few carmakers that spells out a service interval for transmission oil change. Many (most?) carmakers and their dealers are spewing the "sealed for life" nonsense story. 100,000 miles / 160,000 kms is the longest I suggest driving without transmission oil change. M-B spells out 6 years / 60,000 milles which is nice.
anyone knows torque spect and order how to torque bolts Manifold to the block?
Thank you!
I changed my front and rear differential fluid this weekend. It wasn't that bad. I didn't even jack up the car. I drove the car up on two 2x6 pieces of wood stacked on top of each other which allowed me just enough clearance to get the job done.
I used 75w-90 valvoline synthetic for the differential and Shell 134 tranny fluid for the transfer case.
Transfer case fluid was black. Differential fluid was black/brown.
