Running wire from fuse box for dashcam
2022 GLS 450 w/ AMG Night (22" AMG Wheel)
bello
i bought a dash cam and would like to get a wire from fuse box and come out from the roof rear view mirror area.
I found the fuse allocation chart in this forum. Can I just use the empty slots? ( need to test power for hot or running hot circuits) if someone has done this, please let me know which route they went for sticking the wires inside headliner...etc and whichfuse box you went to ( my guess is the passenger side nx to glove box)
I did some searching and found the cig lighter fuse is at the rear of the car. The fuse kit that I bought seems to be too far as the wire may not long enough. Does anyone know if below is possible ,
1. Either add-a-circuit on top of the f15 (electronic compass) which is the last fuse of the box - the kit in bought seems needs some wider clearance and I don't think It has enough room to stick that adapter in the middle of the fuses ) I believe this f15 is a switched circuit. (Power when car running)
Or
2. Is f16-f18 available to use that's connected behind the box? It would be great if I can just use an empty slot)
i have already bought a dash cam fuse wire kit from Amazon.
Spy Tec Dash Cam Hardwire Fuse Kit with Micro USB Direct Hardwire Car Charger Cable Kit for Dash Cameras (Micro USB and Fuse Kit) https://www.amazon.com/dp/B01N686R48/ref=cm_sw_r_cp_api_mAqDzbRJQRYV5
thanks
Or
thanks
Did you find a location for the voltage supply? It's fuse #37, 10amp, in the load compartment fuse box.
