ML 320 ABS Traction code 5967
Old Jul 30, 2019 | 11:43 AM
BenzBallin's Avatar
R350 2008 4Matic Gasoline
ok sorry bout that...Mine is Gas Engine 2008 R350 and part looks like 251 431 04 12
Old Jul 30, 2019 | 06:01 PM
wannawagon's Avatar
2006 ML320 CDI (2 of) and 2008 GL320
is that the number off the black plastic face that houses the electronics and receives the plug? most of the ones I have seen have 545 as the second set of numbers
If you are getting the 5967 I would have thought it would be the same
I was able to just change the motor, had to flex the rear cover away to get clearance to remove and undo but not sure if the cover is the same on a w251
Old Jul 31, 2019 | 07:49 AM
BenzBallin's Avatar
Old Jul 31, 2019 | 07:51 AM
BenzBallin's Avatar
Old Jul 31, 2019 | 08:40 AM
wannawagon's Avatar
Sorry - the code I am referring to is on the black plastic face, on the first photo the plastic face can be seen to the right (the black face faces towards the front of the car in the ML, assume same) - assume motors are the same for them all??? unsure??
In any case it sounds like the motor - I just used a 2nd hand one from EBAY
Maj Dundee said something about brushes being worn but I could not work out how to change them - I think the 2nd photo has the motor shown
How far has your car gone?
Old Jul 31, 2019 | 10:18 AM
BenzBallin's Avatar
yea...the ML are very similar in motor...are these pumps known to go out usually ?
Old Jul 31, 2019 | 11:40 AM
  #32
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
After 11-12 yrs. of use the brushes in the motor wear down.
And you still never provided your vin# as requested.
Old Aug 3, 2019 | 11:35 AM
  #33
BenzBallin's Avatar
Old Aug 3, 2019 | 11:36 AM
  #34
BenzBallin's Avatar
Sorry it is 4JGCB65E08A081310 ...does this part have a fuse or relay ?? the error im getting is sayin Power Supply to high pressure pump
Old Aug 3, 2019 | 01:49 PM
  #35
There are only 3 fuses which power up the ESP Cont. Module. See post #5 for fuse locations.
With the key on check the following fuses with a test light. Do not pull fuses to check them. See video.
Old Aug 3, 2019 | 02:55 PM
  #36
BenzBallin's Avatar
ok Thanks Maj. i will check it now ...also is there a relay that works the Pump Also ?
Old Aug 3, 2019 | 04:01 PM
  #37
BenzBallin's Avatar
So i now checked fuses 109 & 115 and they are good ..but # 6 was not there ..is that one located inside by the battery ?
Old Aug 4, 2019 | 06:09 AM
  #38
No.
Old Aug 4, 2019 | 06:15 AM
  #39
Did you follow the procedure in the video using a test light?
Forget about fuse *6.
Old Aug 6, 2019 | 09:12 AM
  #40
BenzBallin's Avatar
Thanks Maj. yes i checked it and they both lit up fine..im thinkin maybe the pump is bad :-( ..also is it true that the replacement pump needs to be reprogrammed for the car ??? is that dealer only reprogram or can a Indy shop with Star diagnostic can do it ?
Old Aug 6, 2019 | 10:53 AM
  #41
No, the pump does not have to be programmed.
Old Aug 6, 2019 | 11:42 AM
  #42
Looking from the top of the engine, look to see if the Hydraulic Pump could be moved 5 inches to the rear.
Old Aug 6, 2019 | 01:45 PM
  #43
BenzBallin's Avatar
Old Aug 6, 2019 | 01:47 PM
  #44
BenzBallin's Avatar
Vin is ..4JGCB65E08A081310 ,..looking at it from the top..it can maybe go back a couple inches..dont know if 5 inches though" ..attached is a picture at the bottom
Old Aug 6, 2019 | 02:40 PM
  #45
If the brake lines are not in the way then you can probably do it. You will have to remove the motor from the bottom after removing the left front wheel well liner.
Remove the two bolts to the motor and make a mark on one side, so when you reinstall it, the bolt holes will be correctly aligned.
Please read this multi post thread on the subject and decide if you are capable of performing the repair.
https://www.benzworld.org/forums/w16...ml#post4229913
File Type: pdf
Old Aug 7, 2019 | 04:49 PM
  #46
BenzBallin's Avatar
Thanks.....so after scanning it again i also noticedd another error code and have the flap broke in the intake manifold...apparently i gotta change too" .. ...would the car breakdown if i decide not to change or repair the flap on the intake manifold ? im already repairing this Abs pump and 3 weeks ago i had to change the Fuel pump and that was $550+ in parts and Labor...so i dont feel like wasting more money if i dont have to'
Old Jul 31, 2025 | 01:30 AM
  #47
Jibe83's Avatar
ML 280 CDI (DIESEL)
Hola BenzBallin pudiste solucionar el error de la bomba del ABS?
eran las escobillas?
Old Jul 31, 2025 | 01:31 AM
  #48
Jibe83's Avatar
ML 280 CDI (DIESEL)
Hola BenzBallin ¿pudiste solucionar el error de la bomba del ABS?
¿eran las escobillas?
Old Jul 31, 2025 | 01:46 AM
  #49
Jibe83's Avatar
ML 280 CDI (DIESEL)
Hola Mayor Dundee, mi coche es un W164
Old Jul 31, 2025 | 01:48 AM
  #50
wannawagon's Avatar
If it’s just the motor on the flaps you can put a 4.7kohm resistor between two pins to keep the ecu happy and out of limp. Unsure what the Spanish?? Is. Australia
google om642 swirl flap motor delete. You should get a YouTube eventually
