reverse camera issue
Old Sep 2, 2017 | 11:53 AM
DTotham's Avatar
ML320
2007 ML320 - my back-up camera is not displaying on the console
Old Sep 2, 2017 | 11:56 AM
DTotham's Avatar
ML320
to note I have reviewed the other threads. Unlike others who get a blank screen, mine doesn't even activate!?
Old Sep 2, 2017 | 10:18 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Is the camera original equipment?
Old Sep 3, 2017 | 12:17 PM
DTotham's Avatar
ML320
Yes, everything is original. I must admit a few times in the past the nav/radio console used to lock up on a radio station and volume level. Not sure if this is related?!?
Old Sep 4, 2017 | 07:42 AM
Here is everything I have on the Backup Camera. M/B does not supply any tests as the use the SDS to find and correct problems.
The first thing to do is check fuse #37 in the cargo area fuse box and ground. Other than that, you will have wing it.
Attached Thumbnails reverse camera issue-back-up-camera-fuse-37.jpg   reverse camera issue-backup-camera-ground-w6.jpg   reverse camera issue-back-up-camera-loc.jpg   reverse camera issue-back-up-camera-module-n66-10-loc.jpg   reverse camera issue-back-up-camera-module-n66-10.jpg
File Type: pdf
File Type: pdf
File Type: pdf
