Help needed - Run Flat Indicator Inactive
Old Sep 14, 2017 | 02:22 PM
-AJC-'s Avatar
2006 ML 320 CDI
Hi, I have a 2006 ML 320 CDI.
With the engine running when I scroll to the Run Flat menu I have this message:
The owners manual has the following info:
However, the "Menu: R-Button" is not displayed?
I have tried adjusting the tyre pressures, checked fuses, pressed steering wheel buttons in countless configurations but to no effect.
Anyone have any ideas?
Old Sep 16, 2017 | 05:23 AM
flybd5's Avatar
Veteran: Marine Corps
2014 Smart ForTwo Passion Cabrio
What happens when you press the R button anyway when the display says that the Run Flat Indicator is inactive?
Old Sep 17, 2017 | 10:18 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
M/B doesn't tell you everything in the owner's manual. You will have to check for stored codes in the ESP/BAS Module.
File Type: pdf
Old Sep 17, 2017 | 05:27 PM
-AJC-'s Avatar
2006 ML 320 CDI
Nothing happens when I press the R button, or hold it pressed etc.
Old Sep 17, 2017 | 05:30 PM
-AJC-'s Avatar
2006 ML 320 CDI
Thanks, I'll get it scanned and see if any old codes remain. It has had a history of ESP error messages before I replaced the Steering Angle Sensor so likely that an old code will need to be removed.
Old Sep 20, 2017 | 09:04 AM
-AJC-'s Avatar
2006 ML 320 CDI
Ok checked for stored codes in ESP/ABS module but nothing. Any other ideas?
Old Sep 21, 2017 | 04:39 AM
Is your scanner capable of reading the 40 modules in the truck? Look at all the possibilities just for the run flat program.
File Type: pdf
Old Sep 22, 2017 | 10:54 AM
-AJC-'s Avatar
2006 ML 320 CDI
If I buy an iCarsoft MB II OBD reader will this be suitable? My local indie charges £60 per 15 min to use his STAR machine!
Old Sep 22, 2017 | 11:50 AM
I have no knowledge of iCar scanner. You can buy this one from Amazon and it can read every module.
Attached Thumbnails Help needed - Run Flat Indicator Inactive-2017-09-22_114901.jpg
Old Oct 21, 2017 | 08:02 AM
-AJC-'s Avatar
2006 ML 320 CDI
SOLVED
Thanks Maj. Dundee you were right.
Went to a different MB specialist with STAR and he found a menu in the ESP/ABS Module that gives you the option to activate or deactivate the Run Flat Indicator. Hey presto, if you activate the system the "Menu: R-Button" appears.
So if "Menu: R-Button" is not displayed on your dash when scrolling to the Run Flat menu then the system has been deactivated and you need to follow the steps above.
Old Oct 21, 2017 | 08:35 AM
flybd5's Avatar
Perfect example of what I teach my students when it comes to any kind of tool. You don't take your car to a mechanic because he/she has shiny tools, you do so because he/she knows how to use them. And you can't fix an incompetent mechanic by giving them a gift certificate to the tool truck. Any tool is only as good as the human behind it.
I also use this example of a very simple tool that has saved billions of dollars and countless hours of time, but if you don't know how to use it, it'll ruin whatever you are working on.
I would be surprised if there isn't someone here who knows what it is.
