Turn signal indicator
I've had both my rear turn signal indicators display on message board. They are not burned out & work normally intermittently. The left one has not faulted in a long time after cleaning the contacts & frame where it plugs in. The right however is being a real pain. I know they have replacement sockets & they also have wired harnesses you can put in. What is most recommended? Can I change all my bulbs to LED without any upgrades?
AZN Optics (09-15-2017)
LED Lamps were not born until 2009 and are very expensive and have many problems.
Here is the fix to your problem, along with the part numbers at the end.
