Coolant Change Query 2009 ML550
Old Sep 18, 2017 | 08:38 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Hi, I was hoping to change my coolant and was hoping if anyone could tell me if there wee any tricks or traps to replacing it. My approach was pretty much the same as doing it on a 67 Falcon 6 cyl. Drop the hoses, let in drain, then refill through the coolant tank with MB coolant. I'd appreciate any advice on this and if I need to look out for anything. Thanks in advance
Old Sep 18, 2017 | 10:14 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Be careful with removing the lower hose, breakage of nipple. Remember that the hose is above the radiator drain port, so you should also open it to drain the remainder.
Also, don't forget to drain the eng. block on both sides.
Do not use green coolant.
Old Sep 19, 2017 | 06:31 PM
BlackML550's Avatar
Thanks so much for this. Clearly there's more to it than meets the eye. Very much appreciated.
Old Sep 19, 2017 | 07:27 PM
lkchris's Avatar
'10 CL550, '12 GL550
Mercedes coolant life is 15 years, so unless yours has been contaminated not really necessary to change it.
Old Nov 23, 2024 | 07:44 PM
Roberte01's Avatar
2008 CLK 550 Convertible
Anyone know what size internal hex is in the engine block drain plugs on an ML550? (Not that it really matters, they're just about impossible to get to on an ML550 with 4MATIC...)
