2011 ML350
Old Oct 13, 2017 | 08:34 PM
Alquh's Avatar
ML 350 4Matic
2011 ML350
I was changing the brakes on my wife's 2011 ML350 4Matic and had trouble with the rear and the EPB going into pad service mode. My steering wheel looks like the following so it is a bit different than the videos and guides I've seen.
https://www.google.com/search?biw=19...gg9kx91M6JGTM:
Another issue I had was that my mileage would NOT show up in position 1/acc mode. It only showed when I first put my key in the ignition. Any ideas how I can accomplish this? I even called Mercedes dealers and they were either busy or had no idea.
Is this something I _need_ to do on my ML350 or only on versions w166 and above?
Thanks,
Alq
Old Oct 16, 2017 | 08:35 PM
Alquh's Avatar
ML 350 4Matic
BUMP. Can anyone help?
Old Oct 17, 2017 | 06:09 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
[QUOTE=Alquh;7285650and had trouble with the rear and the EPB going into pad service mode. [/QUOTE]
What does this mean?
Steering wheel off center means you need an alignment.
Old Oct 17, 2017 | 10:34 AM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Question
Cant really help but have read threads on this site about changing pads and they mention some special procedure for the rear brakes, has to do with some control on the steering wheel. Hope you get it fixed.
Old Oct 19, 2017 | 05:50 PM
Alquh's Avatar
ML 350 4Matic
Unhappy
I have read that too. I was specifically wondering about my car year, and if I need to do that or not. From what I read, it was only on 2012 and later models, but can someone confirm? Surely someone on this forum has changed rear pads on a 2011 ML350 before..
Old Oct 19, 2017 | 06:44 PM
It's only on W166 chassis. Do you want the instructions to change the rear pads?
Old Oct 19, 2017 | 06:56 PM
Alquh's Avatar
ML 350 4Matic
Thank you for clarifying! Yes, that would be great if I can get that.
Thanks again!
Old Oct 19, 2017 | 07:12 PM
Thanks again!
Here it is.
File Type: pdf
