Steering Column help needed
Any suggestions or help here would be greatly appreciated. Trying to get this fixed this weekend..
Under the right side of the steering column cover, you will see a large access hole. There is no need to remove steering wheel.
At the top of the hole is a bolt which keeps the combination sw. in place. You will need an extended T27 Torx 1/4" drive socket as pictured.
Loosen the bolt slightly and center/level the column cover. Then tighten the bolt, but don't over do it.
At the top of the hole is a bolt which keeps the combination sw. in place. You will need an extended T30 Torx 1/4" drive socket as pictured.
Thoughts?
Here is a picture that shows the column tilted a few degress to high
Here is the hole I put the torx into to loosen
With the bolt loosened enough, but not removed, grab the cover with both hands and give it a quick jerk downwards.
That bolt is supposed to sit in a concave bore hole drilled into the steering column and the bolt is convexed at its tip.
The whole column rotated up but everything works fine and shows properly on the I.C.. It's just rotated..
