2010 ML 350 Bluetec in Limp mode, lots of codes
A bunch of codes were thrown:
P2009 Intake manifold runner control stuck open bank 1.
P2005 Intake manifold runner control stuck open bank 2.
P2006 Intake manifold runner control stuck closed bank 1.
P2007 Intake manifold runner control stuck closed bank 2.
P0112 Intake air temp sensor 1 circuit low input
P00AC*Intake air temp sensor 1 circuit low bank 2
P0489 Exhaust gas recirculation control circuit low
P0031 HO2S Heater control circuit low (Bank 1 sensor 1)
P0102 Mass or Volume air flow circuit low input
P010C Mass or volume air flow B circuit low.
P0100 Mass or volume air flow circuit
P010A*Mass or volume air flow B circuit
P0047 Turbo charger boost control solenoid circuit low
I cleared the codes and drove it a short distance and the coolant symbol reappeared and it never did get out of limp mode. I then cleaned the MAF sensors and the passenger side one was visible dirty and covered in oily residue. I replaced the intake tube and sensors and there was no change. I suspect that the pass side MAF is gone south and my cleaning did nothing.*
I have researched the stuck intake runners and it seems that there is a after market fix with metal parts to replace the plastic that breaks. My question is: are the kits available the same for the gas and diesel motors? I have found the kits on ebay but none specify that they are for the Bluetec.
Anyone else experience a similar issue? *I am looking to diagnose and do the work myself as I have already sunk $6500 in it recently for a bad add blue pump and regulator in addition to a bad HK amp.*
Any help would be much appreciated.*
thanks
Shalil.
https://www.mbpartsexpress.com/auto-...mercedes-benz/
Put in your model info, and search for the intake manifold assembly and parts. Write down the part number. Then go back and cjhange the model number or whatever, to get the other type of engine (gas versus diesel). Compare part numbers. They're very likely different.
Brucerman, in WPB, FL
