2011 bluetec going in to limp mode randomly
Old Feb 23, 2018 | 05:31 PM
dc2k's Avatar
2011 ML350 Bluetec
hey guys does anyone know how to fix these codes? my truck goes in to limp mode cant rev past 3k, just got done fixing some issues this past January, and now its acting up again. Here are the codes from my scanner
11500 - the regeneration of the dpf is not ok.
106100 - the upper limit value for long term adaptation of the scr exaust aftertreatment has been exceeded.
123900 - charge pressure is to low.
16da00 - the postive control deviation during boost pressure control is to high
14b200 - a plausibility error exists in the component hot film mass air flow sensor.
I checked the charge pipes and its good, aswell as the connectors on the maf sensor. after clearing the codes this code always stays on
thanks
Old Aug 24, 2018 | 03:52 PM
phlfly's Avatar
ML320 BlueTec, 09 E63 AMG, 91' 350 SDL
any resolution ?
Old Oct 1, 2018 | 02:34 PM
dc2k's Avatar
2011 ML350 Bluetec
yeah the gasket on the charge pipe was missing i installed that and everything was good. still have the 106100 code
Old Oct 1, 2018 | 08:22 PM
chsu74's Avatar
GL 450, 993TT, Cayenne Diesel, 964C4
I would run liqui moly dpf cleaner and go for a long highway run. It will smoke like a coal train. Can do that a few times. I had fail regen fail code 60+ times and liqui moly cleared
Old Oct 29, 2020 | 11:49 AM
Bozza P's Avatar
S w221
That's the one
Old Oct 29, 2020 | 12:05 PM
Bozza P's Avatar
S w221
That's the one
