ML500 air suspension question.
I got some decent pricing on the parts:
$280 AMK compressor
$250 Rear Arnott bags for both
$240 a piece for fronts.
Thanks for any help. Bill
You need to simultaneously insert a long bar through the "U" in the strut to compress it, whilst pushing down with your foot on the A-arm. If you have the Offroad package, you will need to remove the bash plate to allow the A-arm to drop sufficiently. Ensure you only have one of the three upper strut nuts installed, and leave it loose.
The combination of these actions allows plenty of room to lift it over the driveshaft.
PM me if you'd rather not share.
OP has the offroad package fitted - same as mine.
For cars fitted with the offroad package, the engine bash plate must be loosened or removed to allow the A-arm to drop down far enough, so that the strut clears the driveshaft. The vehicle in the Arnott's Youtube video does not have the offroad package fitted and they make it look so easy!
. I see you've just joined the forum. Welcome!
