Radio turning on and off
Old Mar 24, 2018 | 06:12 PM
dilaxsan65's Avatar
Ml350
I have a 2006 ML350 and the radio keeps turning on and off, it used to turn on and work for a few days then turn off and keep repeating it self but now it completely shut off and won't turn on. I took out the radio unplugged it and plugged it back in, it would work for roughly 30 seconds and turn off again then it won't turn back on.
Old Mar 25, 2018 | 07:09 PM
wannawagon's Avatar
2006 ML320 CDI (2 of) and 2008 GL320
I had a similar problem on my car with the Command (is that your head unit?). It actually happened the first time when I plugged in a scanner but I think it was coincidental - the controls on the head unit were not responsive - only the steering wheel buttons would respond.
I found the only way was to disconnect battery - wait say 5 minutes - then reconnect battery.
It has happened 3 times to me (all about a week apart) but the last time it happened was about 2 months ago. I was wondering if it was ambient temperature related (Australian Summer).
I can't see anything different in disconnecting radio (and disconnecting battery) but It could be worth a try
Old Mar 26, 2018 | 04:55 AM
flybd5's Avatar
Veteran: Marine Corps
2014 Smart ForTwo Passion Cabrio
The Comand system is composed of more than just the head unit. There are other components in other places of the vehicle, which might explain why disconnecting the battery would help with this, but remember that when you do that there are steps to follow to reenable systems in the vehicle. READ THE OWNER'S MANUAL.
Old Mar 26, 2018 | 08:12 PM
wannawagon's Avatar
Ok thanks, will do.
I know this is a bit off topic but do you know of any way to turn the Bluetooth off when the key is in position 1 or removed?
I have two cars - both 2006 ML320cdi (one with command, and one with std) both with MB Bluetooth adapter under armrest. Both cars will take the phone call away from the phone handset even if the cars have been locked for hours. (means we have to turn off Bluetooth on phones)
Every other Bluetooth I have had in a car is turn off car and the Bluetooth goes to the phone handset.
Old Mar 27, 2018 | 12:00 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Was the phone/Bluetooth factory installed or was it retro fitted after purchase?
Old Mar 27, 2018 | 01:12 AM
wannawagon's Avatar
As far as I can work out both cars came with the Bluetooth box under the rear seat, and both had the Bluetooth module wiring in the arm rest.
The car with the Command came with the module installed under the armrest (when I bought it) while the other car (normal head unit) I bought a Bluetooth module for later.
They both operate the same way (ie if you walk close to car even if car is off and locked - the call will be transferred to car. - it seems weird and unproductive to me)
Old Mar 27, 2018 | 05:26 AM
Remove the beverage cup and then the stowage box and disconnect the phone.
File Type: pdf
Old Mar 27, 2018 | 07:55 AM
wannawagon's Avatar
Thanks for reply (sorry it took a while to get back)
Is this to permanently kill the Bluetooth adapter (under the armrest)?
or do I do something with the disconnected adapter?
Old Mar 27, 2018 | 08:53 AM
flybd5's Avatar
The bluetooth adapter is under the armrest. He's talking about removing the beverage cup and then the stowage box. Two completely different things.
Old Mar 27, 2018 | 06:36 PM
wannawagon's Avatar
I assume the connector to the Bluetooth adapter is under the stowage box, under the armrest, but I don't want to disconnect it permanently (I could just remove the Bluetooth module from the adapter).
I was hoping there was some setting somewhere that would give me the option so the Bluetooth switches off when the car is off
Old Mar 27, 2018 | 08:47 PM
sclasspilot's Avatar
2008 ML320 CDI with every option code including Offroad pack, 1978 450SEL
There is, actually! This is the correct way to do it.
Create a new phone contact named "Run-on Time" (exactly as written) and set the phone number to the amount of minutes you want the bluetooth to remain on.
I have mine set to 0 and it turns off when I open the door (as I have Keyless-Go).
Old Mar 27, 2018 | 10:05 PM
wannawagon's Avatar
Hi Thanks for that -
Not sure if I did it right but it didn't work (on the car with Command- other car is away)
I created Run-on Time as an iPhone contact (with 0 as number) and went to car.
Car picked up phone, checked address book and Run-on Time was in there. But took key out, and even locked car but when I did a call it went through car, I also tried turning off car halfway through a call and it stayed with car.
Any thoughts?
BTW its good to see a fellow Aussie on here
Old Mar 27, 2018 | 11:24 PM
Any thoughts?
Hmm, not sure why it wouldn't work for you. Restart the phone and also the Viseeo dongle (button closest to the rear) to see if it helps. Unclip/reinstall the Viseeo? Also try 1 instead of 0?
Old Mar 28, 2018 | 01:30 AM
wannawagon's Avatar
Ok - All good thoughts - I will try all of them and let you know.
Thanks again
Old Mar 28, 2018 | 04:19 AM
flybd5's Avatar
I did some research and I doubt this will work. The manual for the bluetooth adapter says this:
Switching off
Deactivation of the hands-free system is delayed by the run-on time. During the run-on time, the hands-free system remains fully available. The run-on time begins, as soon as the ignition is switched off. The run-on time is stopped during a call for up to two hours. After two hours have passed, the hands-free system is deactivated, regardless. The run-on time can be set at a MercedesBenz Service Centre using the vehicle diagnosis system. The standard setting is 30 seconds.
It looks like this parameter is set incorrectly in your vehicle to force the standard run-on time to infinite (and I am surprised this hasn't depleted your battery). I think you either need to take it to the dealer to check and correct this, or find someone with a Star Diagnosis computer to do so (cheaper).
Old Mar 28, 2018 | 05:53 AM
wannawagon's Avatar
Switching off
Big thanks - I think you are right. I too was worried with the battery.
Is there any way this can be accessed through engineering mode on the head unit? I have tried various internet instructions on getting to this mode but none have worked so far (Australian delivery car)
I will see if I can get it scanned with STAR, I have free access to a snap-on Solus scanner but it didn't bring up anything to do with stereo/aircon etc
Old Mar 28, 2018 | 05:58 AM
flybd5's Avatar
STAR DIAGNOSIS. Don't waste your time trying to do anything else. Forget about the Internet for this. You want to solve it, just follow the instructions and take it to a dealer or something with the STAR DIAGNOSIS computer.
Old Mar 29, 2018 | 12:48 AM
wannawagon's Avatar
No worries , will do, closest dealer is 2 hours away - will see who I can find locally with a STAR
Old Apr 3, 2018 | 12:12 AM
dilaxsan65's Avatar
Ml350
hey guys so I unplugged the radio and plugged it back in and it seems to work, but everytime I put the bass high and put the volume up it keeps shutting off then I'll have to unplug and tinker around with it to turn back on .
Old Apr 3, 2018 | 02:11 AM
wannawagon's Avatar
When you say volume hi and bass hi do you mean rock concert hi? Or just easy listening hi?
if rock concert levels it could mean you are having a low current issue and it is closing down from low voltage.
Assume car is running when you are doing this? (Alternator working etc?). Have you tried a voltage test. Even through the one on dash
I remember in my youth I had a house stereo that the lights behind the tuner dial used to blink to the beat when the bass and volume were hi.
Old Apr 3, 2018 | 12:09 PM
dilaxsan65's Avatar
Ml350
It usually shuts off when there's hard bass from the song and mostly when the volume is very high, I've tried leaving on normal listening levels and it doesn't seem to shut off. Also how can I check the voltage thruoug the dash?
Old Apr 3, 2018 | 03:35 PM
flybd5's Avatar
Stupid question at this point, but is this the original radio and sound system on the car? Stock? Not modified?
Old Apr 3, 2018 | 09:33 PM
dilaxsan65's Avatar
Ml350
Yes, everything is stock no modifications have been done to the stereo, and today while driving it there seemed to be some sort of noise coming through the speakers especially as I pressed more gas, but if I turn off the radio it stops anyone know what it might be?
Old Apr 4, 2018 | 05:36 AM
flybd5's Avatar
This is way too weird. My hunch is that you have moisture and corrosion somewhere in the system, most likely in the power circuit. Have you scanned the computer for codes with a scanner that understands Mercedes codes (no, generic scanner won't do)?
Old Apr 4, 2018 | 04:27 PM
As flydb5 said a week ago, there is no easy way to find the problem. The codes must be read. It could be over or under voltage or any other problem.
