2008 ML320 radiator removal
Old May 30, 2018 | 09:33 PM
Allen Sadler's Avatar
ml320
Can anyone help me to get the radiator out of a ML320 with instructions?
Old May 30, 2018 | 11:42 PM
ItalianJoe1's Avatar
2003 CL 600
Merry Christmas.
There will be some overlap in the documents, due to how the Germans put WIS together. The radiator doc will link to the "remove charge air cooler" document, but it may not be necessary to fully remove it, if you are just removing the radiator. Use a little common sense and you can usually avoid doing extra steps as opposed to just following down the list of each one. Hope this helps
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old May 31, 2018 | 05:37 PM
ml320
Tricks
Have the documents but I can not seem to get the condenser to separate from the radiator. Is there a trick to this? Is there a latch between them I am missing or something? I have removed the bolts I can find and even took the bottom support plate out. They are floating in there but I can still not separate them!
