Recommended Engine Oil
Old Aug 17, 2018 | 01:57 PM
Elchins's Avatar
Mercedes Benz ML350 4MATIC W164
My question is related to W164 ML350 2009 model.
Car is on 115000 mile.
What viscosity, oil brand i should use for this car. Expensive one is not problem. Is there any choice of oil viscosity for high mile vs to new low mile car ? As far as i now recommended oil should be 0w-40.
for Mercedes Benz brand oil is identified with car vin number. There is no specific viscosity on MB oil sticker.
Old Aug 18, 2018 | 09:16 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Call the parts dept. at any dealer with your vin# and ask them what Eng. Oil sheet # you should use. Then post back and I will supply the sheet # oils.
Old Aug 19, 2018 | 03:58 AM
Elchins's Avatar
Mobil,shell,luk oil, castrol;mercedes benz.valvoline, Titan
Old Aug 19, 2018 | 07:03 AM
What was the sheet #?
Old Aug 19, 2018 | 12:58 PM
Elchins's Avatar
Ok, i do not understand what sheet you are asking. Leave it. Thanks for commenting.
Old Aug 19, 2018 | 05:10 PM
CLK Group's Avatar
2008 ML320CDI 4Matic, 2006 C350
For gasoline engines: https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
For diesel engines: https://bevo.mercedes-benz.com/bevol...229.52_en.html
"Which are distinctly marked with the label indicating the approval of Mercedes-Benz, e.g. “MB-Approval 229.51”. Labels referring e.g. to “MB 229.51” don't have an approval of Mercedes-Benz."
"Which are listed in the current MB BeVo. Only listed products are tested and approved by Mercedes-Benz."
Old Aug 21, 2018 | 09:04 AM
Elchins's Avatar
is there requirement to use different viscosity due to car milage. My car is now 116848miles. Is 5w40 as mentioned in bevo ok ? Because, Bevo might consider thouse grade for newer cars. Any idea ?
Old Aug 21, 2018 | 10:55 AM
Here is the viscosity chart,
File Type: pdf
Old Aug 21, 2018 | 03:54 PM
lkchris's Avatar
'10 CL550, '12 GL550
You’re going to run into the fact that 229.51 is essentially obsolete and is replaced by 229.52.
As for viscosity, you’ll probably find only one: 5W-30. This will be fine year around in any climate on earth.
Old Aug 22, 2018 | 03:27 PM
Elchins's Avatar
As far as i know 229.52 & 229.5 is diffetent sheet #.
It was stated in owner manual for 2009 year, 229.5 spec to be used & this spec is still available on bevo website. Btw, my car is gasoline & not diesel.
Old Aug 23, 2018 | 04:01 AM
Correct.
