Adaptation/Software update/reprogramming of transmission
Old Sep 7, 2018 | 12:01 AM
Elchins's Avatar
Mercedes Benz ML350 4MATIC W164
Is one if these "Adaptation/Software update/reprogramming of transmission" required to do when changing transmission oil at every interval ?
Is there possibility of trial version of this software to be installed in TCU ? If yes, how to check to avoid this.
Why i should do software update or whatever called to my car's transmission ? Once this was done by manufacturer. What happens ?
Transmission is not smooth when it shifts from 2 to 1. As far as i know, this is known issue with 722.9 transmission. Only way is o get the TCU updated, okl changed or conductor plate replaced.
Old Sep 7, 2018 | 05:57 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
There is no adaptation necessary when changing trans. oil.
Where did you get your information?
Old Sep 7, 2018 | 08:13 AM
Elchins's Avatar
Heard from someone.
What about transmission software update to fix shifting issue from 2nd to 1 when rolling the car to stop?
Old Sep 7, 2018 | 08:33 AM
Originally Posted by Elchins
Heard from someone.
Heard from someone is useless because there is nothing to back it.
I had the same exact issue and a fluid & filter change corrected the issue. Do not drain the trans. pan as there is no fill tube. Fluid is inserted into the pan by using a pump.
