need to know if my benz has keyless go?
Old Oct 29, 2020 | 07:23 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
If your door handle does not look like this, you do not have Keyless Go.
File Type: pdf
Old Nov 3, 2020 | 07:35 AM
S.O.B's Avatar
ML 350 2007
Can I use the push-start button to start my car engine?
[QUOTE=bha;7574131]Buy a used one on eBay or from a wrecking yard. I believe most (70% or possibly more.. should ) of the Ml and GL models in the US had Keyless Go.
Just make sure the vehicle had Keyless Go and it will fit. Get the VIN if you can and we can tell you for sure.
BTW I looked up your VIN and your vehicle does have Keyless Go listed as an optio
I have the ML350 & my VIN is: 4JGBB86E77A228422. Thank you.
Old Nov 3, 2020 | 07:43 AM
S.O.B's Avatar
ML 350 2007
Will PUSH-START button work on my car?
Please, I wish to know if the PUSH-START button can work on my car before purchasing it. I own a 2007 model ML350 with VIN: 4JGBB86E77A228422. Thank you.
Old Nov 3, 2020 | 02:28 PM
No you cannot use the button because it is not a Keyless Go veh.
As per the vin# it does not have Keyless code889.
Old Nov 4, 2020 | 10:33 AM
Denen Kpojime's Avatar
ML 350 2013
Does my car have the keyless start/go? Vin: 4JGDA5HB4DA257658
Does my car have the keyless go feature, and can I buy the engine start/off button off Amazon, insert in my ignition and drive as a keyless vehicle instead of having the key in the engine the traditional way? Thanks
Old Nov 4, 2020 | 11:30 AM
If you don't have this handle you don't have it.
File Type: pdf
Old Nov 4, 2020 | 02:49 PM
  #32
ML 350 2013
Does my car have keyless go?
My door handle looks like that, but doesn’t have the black rectangle on the door knob, but has on the key hole. I thought you could tell from the VIN?
Old Nov 4, 2020 | 04:27 PM
  #33
You still do not have Keyless Go because you do not option 899 (Keyless). I hope you are satisfied.
File Type: pdf
Old Nov 5, 2020 | 07:31 AM
  #34
ML 350 2013
Ok. Thanks a lot. I appreciate the help
Old Nov 15, 2020 | 12:25 AM
  #35
ML 350 2013
Data card to check specifications on 4JGDA5HBXCA084551
Hi, Maj
can you please send me the data card for 4JGDA5HBXCA084551. Would like to know what features I.e, electric folding mirrors and keyless start/go this car has and what it doesn’t have. Intending to buy it, but I noticed for instance the mirrors don’t fold in when you lock the door and I’m wondering perhaps it may not have the feature of hasn’t been set yet? Thanks
Old Nov 15, 2020 | 01:47 AM
  #36
Next time don't try to BS me about weather or not you have KeelessGo.
File Type: pdf
Old Nov 15, 2020 | 05:34 AM
  #37
ML 350 2013
Old Dec 30, 2020 | 03:42 PM
  #38
S.O.B's Avatar
ML 350 2007
VIN: 4JGBB86E77A228422. I'd appreciate if you could assist me with my vehicle data card. Thank you. I read in the information supplied by the seller that my vehicle comes with keyless entry. I'm quite confused.
Old Dec 31, 2020 | 06:31 AM
  #39
Here it is.
File Type: pdf
Old Dec 31, 2020 | 06:57 AM
  #40
S.O.B's Avatar
ML 350 2007
Here it is.
Thanks so much.
Old Jul 18, 2021 | 11:45 AM
  #41
nazar2491benz's Avatar
ml 350 2006
BTW I looked up your VIN and your vehicle does have Keyless Go listed as an option
hello i have a ml350 2006 can you please check if i have keyless go option WDCBB86EX6A111074 thats my vin number
Old Jul 19, 2021 | 01:26 PM
  #42
You do not have code 899
Old Oct 9, 2022 | 12:02 PM
  #43
kademi80's Avatar
2013 glk 350
Hi guys i buy salvage 2013 GLK350 from iaai please can you check my vin and tell if it has keyless go thank you
WDCGG5HB7DG094995
