Rear Turn Signal Error (08 ML350)
2008 ML350 4Matic
Sometimes when I use the left turn signal, it blinks fast as if a bulb is out. The bulb is not blown. Sometimes it works normal, sometimes it blinks fast as if something is wrong. What could it be?
08 ML350
08 ML350
It's probably the socket. It's a pretty regular problem that can be fixed by cleaning all the connections in the socket and making sure the metal connections can actually make contact with the bulb.
there is also a repair kit available from mercedes but I was able to fix both of mine by cleaning in it up.
