Weird noise whining on morning start ups.
Old Jan 29, 2019 | 10:43 AM
Shehab-Kruz's Avatar
ML-350 4-MATIC
Hello everyone,
I have a 2009 ML-350 4-Matic that had done 102.000km and for a week now I have been hearing a weird whining noise when I start the car in the morning when the engine is still cold.
The noise goes on for roughly 90 seconds and then goes away.
Is this the belt acting up on me? Even though I just changed it about 5 months ago? Or is it just the morning coldness's fault?
I'll provide a voice recording as soon as I can.
Thank you in advance.
Old Jan 29, 2019 | 11:09 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
When the eng. is cold, remove the belt and start up the eng. If the noise is still present, it is an eng. issue.
If the noise is not present, then it could be the belt, or either of the idler pulleys or the tension pulley. Manually spin those pulleys by hand and they should have drag to them. If they spin fast, then they must be replaced.
Old Jan 30, 2019 | 09:39 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Electric Air pump. Runs on startup to heat the cat and then turns off.
Old Feb 2, 2019 | 10:27 AM
ML-350 4-MATIC
Update (File attachment)
Sorry it took a while but I have the recording of the sound in question.
Old Feb 29, 2020 | 08:32 PM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Hi, did you ever find out what the noise was? Was it the smog/air pump?
regards
