TranNY Trouble
Old Feb 9, 2019 | 10:23 PM
David S Vickers's Avatar
Ml350
TranNY Trouble
My car (2008 ML350) went into limp mode and had code 0748 Y38y1 fault. Pulled the pan and valve body and replaced the Y38y1 solenoid. Put back together, new filter and oil. Ran ok for a week then limp mode again with same code 0748 but now Y38y1 solenoid. Pulled again and replaced the Y38y1 solenoid, new filter and oil. Back again ran great 2 weeks then limp mode again with same 0748 code and same solenoid Y38y2. Anyone have an idea what is wrong? Should I replace all solenoids? Could the conductor plate be the fault. Time for a pro? I have a Cream VIII reader so cdes have been cleared each time
Old Feb 10, 2019 | 02:53 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Any time a component is replaced, adaptation of the trans. must be performed.
Old Feb 10, 2019 | 02:51 PM
Ml350
Thank you, I have never had an adaptation done before, would you mind explaining how I do it?
Old Feb 11, 2019 | 04:40 AM
David, I provided a video showing you what has to be done. Did you watch it? Every component has its own procedure.
Star Diagnostic must be used.
