Engine 272967 signaling defects: 1208 1200 Synchro.
Old 02-13-2019, 03:34 AM
Michel Duruflé's Avatar
ML350 engine 272 967
WDC1641861A042386
MERCEDES-BENZ ML 350
Hello,
I need the list spare parts engine Mercedes "272967" on signaling defects:
1208 Synchro. tree cams admission
1200 Synchro. camshaft escape
(Camshaft phasors must be replaced with camshaft balancer gear.
Very cordially
Old 02-13-2019, 06:31 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
According to the codes you posted, you have a major repair ahead of you. If the balance shaft is damaged it requires the removal of the eng.
But just to see if the bal. shaft is damaged, you must remove the timing case cover, which is also a major undertaking.
Michel Duruflé (02-13-2019)
Old 02-15-2019, 03:51 PM
Balance Shaft DTC P0016 & 17 #1.pdfWDC1641861A042386
Hello,
Very cordially
Maj. Dundee
Michel Duruflé :
Hello,
Does the kit A2720300613 replace the old kit A2720300213 (found mostly in Eastern countries)
Is the list of spare parts modified?
Very cordially
cordially
Old 02-15-2019, 05:41 PM
Michel, these repairs are extremely complex and requires a mechanic who has done this job before or have M/B do it.
Reference to the parts list is a moot issue if M/B does the job. In any event you must buy the parts from a dealer.
Old 02-16-2019, 04:01 AM
So why did you send me this MB repair document?
Old 02-16-2019, 11:38 AM
It's not a repair document, it's a bulletin to show you what the problem is with certain codes.
Old 08-17-2019, 06:47 PM
Jamaar Brown's Avatar
2010 e350 4matic
So I have a 2010 E350 and I am getting these codes I cant find anything I know I am, excuse my language, ****ed but pls help me know what happened.
Old 08-18-2019, 06:53 PM
Towmater's Avatar
Ml350 bluetec
What happened is you take it to the dealer to get fixed. And the motor comes out along with the money in your wallet.
Old 08-18-2019, 06:58 PM
2010 e350 4matic
Damn i am sad now
Quick Reply: Engine 272967 signaling defects: 1208 1200 Synchro.
