Command Wire Diagram?
Old Mar 21, 2019 | 11:23 PM
CreativelyChris's Avatar
2009 ML350
I'm replacing my command system (w164 2009) with an updated android head unit - does anyone have a wiring diagram of the command unit? Mostly I'm curious on the different colored cables (GPS, ANT, MIC, etc) so that I have each routed to the correct place.
Also, the new head unit seems to get terrible radio reception (assuming I have the correct cable going into the HU (white with purple?)... is there anything odd/different about what the command unit expected or what the antenna sent?
Thanks!
Old Apr 1, 2019 | 02:42 PM
JPortyansky's Avatar
2010 ML 350 4matic
Thanks!
Which radio did you get? And what year vehicle? I am currently in the same boat as far as reception goes. I still have not figured out which oem wires are for the steering wheel controls. Back to the reception. I think the problem is the antenna adapter that was provided. I believe we need one with a built in relay.
