Rear 12V Cigarette Socket has no power
Would anyone have a wiring diagram for this model so I can trace the power through from the fuse box to the socket?
Are you referring to this socket? If so, remove key out of ignition. Pry out socket with plastic pry tool..
Turn ign. on and test BLK/Blue wire for 12v and test Brn. wire for GROUND.
https://en.wikipedia.org/wiki/ISO_4165
Like all USA Mercedes, yours came with the "smoker" option. You can replace your actual cigarette lighters with more ISO 4165 sockets if you wish to make it officially a nonsmoking car.
The cargo area socket is not cig. lighter, it is a 12v charging port. Cig. lighter sockets are completely different from charging ports.
