ADS Airmatic Malfunction
Old Jun 24, 2019 | 03:03 PM
OUZO Power's Avatar
JGC SRT, ML 550, GLB 250
Has this warning popped up for anyone here?
History: Last month I found the entire front end drooped down. I thought the airbags blew in the front. It turned out to be the right rear ride height sensor snapped off. All was well. Everything worked perfectly.
3 weeks after I get this warning and the car is 1" higher all around and locked in sport mode. Can't switch it to comfort or ADS. If I press the raise button it works and compressor kicks in and raises the truck. When I press to drop it it does but takes much much longer. After a few restarts it went away for 2 weeks.
5 weeks after its come back with the same symptoms. But constant now. Went away on two starts but once restarted it came back.
Has this happened to anyone?
Old Jun 24, 2019 | 06:05 PM
texterted's Avatar
ML420 W164 (2009)
Get a reader that can deal with Mercedes Codes.
That (above) is a link to an example. It may provide some clues.
Old Jun 25, 2019 | 03:38 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
I don't have Airmatic, but how did the front end drop when the left rear sensor was the problem?
Old Jun 25, 2019 | 01:17 PM
OUZO Power's Avatar
No idea bud. But that's what happened. We just put on a new sensor in the back and it all leveled off.
UPDATE: Now its all working fine. Lets see how long that lasts. It will come back for sure.
