CDI DPF actually bad?
I have read through dozens of threads on here and benzworld. However I have ruled out a few items as they been done recently or are still in good condition. When they purchased the vehicle the dealer had just replaced and updated the oil cooler, they serviced the transmission and update the software along with replacing the valve body. At the time I only heard and knew of those two items being the biggest issue. I probably should have researched a bit better. Our indy is a prior MB Tech and only uses original parts including vehicle specific oil and fluids from the dealer so with that being said the correct oil was being used and prior to their ownership it was a dealer maintained vehicle with no expense spared (hoping the dealer was using correct fluids as well).
Since they have owned the car it's been used as my father's daily commuter doing roughly 140 miles daily. Turbo actuator replaced, glow plugs replaced, fuel filter replaced every other service and he refuels at the same Shell station religiously. My father also has a bit of a heavy foot so it's not being putted around.
So this brings me back to the topic of discussion. I asked our indy if the DPF is truly clogged and if the sensor isn't the issue. He explained they tested the signal and ran the sensor through his MB computer and all checked out. I asked my parents about ever seeing a weird dash light in regards to the regeneration taking place and neither have ever seen it come on or notice any of the symptoms of regen working. I use the SUV regularly as well and have never seen or notice regen in action. I am bit lost as it's a hard pill to swallow having to pay $2K on replacing the DPF filter on a 13 year old vehicle. Any ideas of what we can look into diagnosing the issue or tips on forcing the regen to start if it's truly the issue.
my ‘07 GL is pretty low mileage and when I asked service advisor when dpf replacement is likely he suggested 100k miles. Also said cleaning instead not a good option ... he would of course but I don’t doubt he’s correct.
as for replacement cost, you’ll either pay to have it done or it will come off what you get selling the vehicle. It was warranted to 80k miles/8 years, which is federally required for emissions equipment. This is part of the diesel experience ... gasoline fuel injectors aren’t $700 each, either.
Update: I went and picked up the DPF off the vehicle today. I can see the honeycombs and it does not look clogged. There is obviously black soot but nothing that caught my eye as excessive or clear build up, it's also the original DPF and the ML now has 108K miles on it. I'll try to post a picture in a little to see if anyone has an opinion of the DPF being the cause of all these issues. Again on CEL on the dash just cuts the boost off randomly. Now that it's off I'll take the opportunity to have it cleaned but something tells me it's the DPS sensor that's causing all of these issues.
You've posted a cabin air filter procedure and we’re talking engine air filter.
