Cigarette Lighter plug Wiring Diagram?
2010 ML350 Bluetec
2010 ML350 Bluetec
Have taken out my cigarette slide out tray and lighter to put in a switch panel for my Volunteer Firefighter strobe lights , a spare switch and USB ports with a Voltage meter on them.
I'm using relays so load on the switches won't be an issue.
Question on the wiring colours to be sure
When measuring them with a multi meter I am getting the following;
Orange - Ground?
Black Grey - 13.9 volts ( with it running )
Brown White - 5.14 with lights on and .5 with lights off
Thanks in Advance
Orange - Ground?
Thanks in Advance
2010 ML350 Bluetec
Wired it to that and everything is perfect .
Mis judged the depth of the ashtray slide tray was mounted so I need to shim my switch panel out a bunch , but like the way it turned out.
