Power Steering Pump compatible with Speed sensitive sensor
Old Jul 29, 2019 | 06:06 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi There,
How would I know if a new power steering pump that I'm going to purchase is compatible with the speed sensor. What happens if I install a pump that is not compatible with this feature.
Thanks,
Old Jul 29, 2019 | 10:57 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What ML are you referring to?
Old Jul 30, 2019 | 12:18 AM
anavabi's Avatar
2006 ML500
Old Jul 30, 2019 | 12:20 AM
I should have asked this before, but why do you want to change the pump?
Old Jul 30, 2019 | 12:25 AM
anavabi's Avatar
It was diagnosed by MB dealer. Stiff steering at low speed when engine hot. When cold steering is fine.
Old Jul 30, 2019 | 12:41 AM
I don't believe the dealer. The pump only has one function and that is to pump fluid.
Are you yourself going to replace the pump?
Old Jul 30, 2019 | 01:04 AM
anavabi's Avatar
Yes
Old Jul 30, 2019 | 04:15 AM
Here are the instructions.
File Type: pdf
Old Jul 30, 2019 | 06:10 AM
anavabi's Avatar
Thank you. My car is equipped with y10 sensor. How do I ensure that the pump is compatible with this feature. Apparently there are two types. I'm buying from Amazon.
Old Jul 30, 2019 | 08:38 PM
What is your full vin#?
Old Jul 30, 2019 | 10:04 PM
anavabi's Avatar
4JGBB75E36A067142
I'm buying this from Amazon. They just go with make model and year.
Old Jul 31, 2019 | 02:24 AM
Here is the part number.
Before you buy this part, understand that the pump is very simplistic, it just pumps fluid and the only time it should be replaced is when the pulley fails.
It has nothing to do with the problem you are having. Your problem is either with the reservoir or the Y10 valve.
Another warning is, non OE parts will not mate up properly with after market ones, e.g., aftermarket pump to OE reservoir and vice versa. And a special bleeding procedure is required after replacing any part in the PS system.
For your financial sake, please think this over.
Old Jul 31, 2019 | 04:48 AM
anavabi's Avatar
The reservoir is OE and replaced recently because it was leaking. Replacing Y10 is hell of a job apparently. Is it a DIY job? And what a sign of a sailed pulley?
Old Jul 31, 2019 | 06:02 AM
The sign is if it wobbles.
No it is not difficult to replace the SPS Valve. But it might not be the problem.
Is or was the ESP light on at any time?
While turning the steering wheel under any condition, is there a groaning sound or any other sound?
How long ago did you replace the reservoir and did you have this problem before the replacement?
Did you read the procedure for draining and refill of the reservoir and did you follow that procedure or you didn't know there was a procedure?
Do you have a scanner to check for codes in the ESP control module?
Copy and paste my questions and answer alongside them.
Old Jul 31, 2019 | 09:16 AM
anavabi's Avatar
Is or was the ESP light on at any time? Never
While turning the steering wheel under any condition, is there a groaning sound or any other sound? No noise at all; just hard to turn
How long ago did you replace the reservoir and did you have this problem before the replacement? 2 weeks ago; and, yes
Did you read the procedure for draining and refill of the reservoir and did you follow that procedure or you didn't know there was a procedure? It was replaced by the dealership 2 weeks ago. Last year I replaced the reservoir myself following the procedure, still no effect
Do you have a scanner to check for codes in the ESP control module? I do. Scanner has no code. Dealer ran their special code reader, star I believe, and reported no code at all.
Old Jul 31, 2019 | 10:39 AM
Thank you for the answers. So the reservoir was replaced twice because there was a leak? Correct?
Old Jul 31, 2019 | 10:46 AM
anavabi's Avatar
Yes
Old Jul 31, 2019 | 10:49 AM
anavabi's Avatar
And there is no wobble on the pulley
Old Jul 31, 2019 | 11:52 AM
This is a tough call to make. If you want to replace the pump, you must be sure that it is an OE one and not an aftermarket one.
And if you replace the pump the front wheels must be raised off the ground and the steering wheel must be turned from lock to lock until all the bubbles in the reservoir are gone
Old Jul 31, 2019 | 12:55 PM
anavabi's Avatar
Why does this happen when engine is warmed up?
Old Jul 31, 2019 | 12:58 PM
You have already asked this question and I said I have no idea.
Old Aug 1, 2019 | 04:30 PM
bbspoolside's Avatar
2007 Gl450 2006 cls55
I had the same problem on my gl x164 and it was the power steering pump failing also it’s the same pump weather you have speed sensitive steering or not
Old Aug 1, 2019 | 05:36 PM
anavabi's Avatar
good to know. Was your steering ok when cold but hard when warmed up too like mine?
Old Aug 15, 2019 | 03:30 PM
Yes it completely cured my problem
Old Apr 10, 2020 | 04:15 PM
gio_gio88's Avatar
S63 W221
Hi, I have the same problem with my ML500 and if you can please tell me, how you solved this problem ?
