P0455
Old Aug 2, 2019 | 04:06 PM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
P0455
A little help please. This is my 3rd P0455. My W211 had a purge valve / cage TSB. The W209, I used an after market fuel sender and had to replace fuel pressure sensor with the OEM one. Now my W164 is giving me the blinking fuel reserve light with the red gas cap warning and CEL. The purge valve is clicking away (like it's supposed to), the gas cap gasket was changed. Hoses under the hood all look attached and intact. Where is the fuel pressure sensor located? Any sage advice would be also be appreciated.
Old Aug 3, 2019 | 04:00 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You are on the wrong forum.
https://mbworld.org/forums/e-class-w211-20/
Old Aug 3, 2019 | 10:07 AM
Pmarino's Avatar
2007 ML 500 ?
Old Aug 29, 2019 | 10:38 PM
Pmarino's Avatar
Hose identification please. Located near the EGR valve.
Looks like it should be attached to something....
A hose to no where, on top of the bell housing?
Old Aug 30, 2019 | 03:10 AM
If you are referring to this part, it is a breather and is not disconnected from anything else. That's the way it is supposed to be.
Old Aug 30, 2019 | 03:12 AM
If you are referring to this part, it is a breather and is exactly the way it is supposed to be.
Old Aug 30, 2019 | 07:39 AM
Pmarino's Avatar
Thanks, What about the one on the bell housing?
Old Aug 30, 2019 | 07:41 AM
That is also a breather hose for the trans.
Old Aug 30, 2019 | 08:01 AM
The Fuel Pressure Sensor location.
What do you mean by this.................This is my 3rd P0455?
Old Aug 30, 2019 | 08:32 AM
Pmarino's Avatar
Had this same code on the W209 and the W211. Thanks for the location, glad I don't have to pull the tank
Old Apr 1, 2020 | 05:21 PM
Pmarino's Avatar
Ok I'm finally getting around to posting my fix......it was the charcoal cannister. Replaced with an after market one, 3 months and all is well, no CEL.
