Power steering pump
Old Sep 9, 2019 | 05:28 PM
rde1492's Avatar
2006 ML350
Power steering pump
I am installing a new power steering pump with new pulley.
Is there anything else I should purchase?
Old Sep 9, 2019 | 08:20 PM
lkchris's Avatar
'10 CL550, '12 GL550
O-ring that seals reservoir to pump.
Old Sep 10, 2019 | 04:16 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What 350, gas or diesel? If it's diesel, supply full vin # as there are different part numbers.
Old Sep 10, 2019 | 09:05 AM
rde1492's Avatar
2006 ML350
Gas
It is a gas model. Thank You
Old Sep 10, 2019 | 09:08 AM
One other question. Why are you replacing the pump?
Old Sep 10, 2019 | 09:11 AM
rde1492's Avatar
2006 ML350
Power steering pump
It leaks
Old Sep 10, 2019 | 09:37 AM
It leaks
I figured as much. The leak is always caused by the seal at the reservoir. Buy the seal at a dealer and install.
Then follow instructions for proper bleeding.
File Type: pdf
Old Sep 17, 2019 | 10:23 AM
RudiVenter's Avatar
2004 ML500 (W163),2006 ML500 (W164)
Interesting, I had a leak on my ML500 as well and the local repair shop insisted on replacing the pump, also insisted on replacing the steering rack as it also had a leak. That was before I found this forum, thanks for sharing your knowledge with us!
Old Oct 2, 2019 | 10:54 AM
RudiVenter's Avatar
Since I wrote the post above I have received the vehicle back and it is going really well. I was really happy till I noticed there was STILL a power steering fluid leak, not fun since I am very far from home and no real support close! Thinking of Maj Dundee's post I did some investigation and yes, the leak is where the reservoir feeds the system!! Not much I can do now, I did manage to find some MB power steering fluid so I will simply have to top it up regularly till I get back to civilization.....
Seems like I spend a lot of money on a fix that was the wrong one. Sadly I only discovered this forum AFTER the ML500 was already in the process of being "fixed"....
Other than this little issue I am really having fun with the ML on some African back roads.
Rudi
