15 chimes when starting, is that normal??
Old Sep 10, 2019 | 09:01 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
Driving my daughter's ML, which I don't do often. I count 15 chimes when starting and I don't believe any of my other MB's chime that many times. Is it trying to tell me something?
Old Sep 10, 2019 | 09:09 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What vehicle are you referring to, model and year?
Old Sep 10, 2019 | 10:21 AM
eddieo45's Avatar
Sorry; that would be the 2010 ML350....
Old Sep 11, 2019 | 04:25 AM
Are there any lights on the instrument cluster, CEL or ESP, etc?
There must be something wrong the would activate lights.
Old Sep 11, 2019 | 07:29 AM
eddieo45's Avatar
no lights, no codes with generic OBD scan tool, just 15 chimes. how many does yours make?
Old Sep 11, 2019 | 03:47 PM
Does this happen when the key is inserted in the ignition or after the key is turned?
Old Sep 11, 2019 | 04:07 PM
eddieo45's Avatar
when car is started.
Old Sep 11, 2019 | 05:03 PM
Read acoustic warnings.
File Type: pdf
Old Sep 12, 2019 | 07:10 AM
eddieo45's Avatar
I've read it; seems the only relevant passage is "Sequence of seat belt reminder warning: In countries with a legally specified seat belt reminder warning the seat belt warning lamp is always actuated for the first t = 6 s (± 2s)."
How many times does your 2006 chime?
Old Sep 12, 2019 | 10:06 AM
You keep asking how many times mine chimes. And the answer is never except when I initiate one of listed scenarios in the PDF.
It is obvious that you might possibly have a problem with the key in ign. while the door is open, even though it is not.
You need a scanner type reader to check for codes in all 25 modules, as your code reader will not do the job.
Amazon Amazon
Old Sep 12, 2019 | 02:37 PM
eddieo45's Avatar
In searching for info on this topic I found THIS THREAD in the W203 Forum where many members - including Super Moderator Glyn M Ruck - commiserate about the 15 chimes at startup in that model. In that thread, members determined it is the seatbelt chime, and if one buckled the seatbelt and closed the door before starting, as I'm guessing you do, no chime sounds, which I have just determined is also the case in our W164. I did hear a femle voice say "Voltage normal, Bluetooth disconnect" upon starting (I did not have my phone).
