Thinking of purchasing 2008+ ML ? What to look for
Either way, I am wondering what stuff to look out for and what is common to go bad on these. I come from European cars and I know that most of them are money pits and need tons of TLC unlike a Toyota/Honda. Only issue is that I live in an apartment condo complex and I can't be removing Engines, Transmission in the underground parking lot, repairs need to be minor to moderate.
So far from what I can tell besides the engine balance shaft they are bullet proof except for the intake manifold plastic bits? These can be retrofitted with metal parts from what I can understand?
How common are the power steering rack leaks? I don't mind the PS reservoir or the wires from the pump to the rack leaking since those seem fairly easy. However it looks like to replace the PS rack you need to remove the differential, which I rather not do.
Do these all have air suspension? Or do the ML350 all have an old strut setup ? Rather not deal with the headaches of the air leaking and compressor dying.
Is there a Mercedes website where you put in the VIN # and it gives a detailed report of which maintaince was performed on a certain vehicle if it was serviced at a MB dealership? I know that with Lexus its possible to look this up?
I also looked into the CDI model? However those look like headaches with all the extra parts. How are they maintenance wise? I know they get better MPG.
The Transmission seems bullet proof? Seems that the common issue is a conductor plate which seems like an easy repair, doesn't require transmission removal? How common is this?
Also what year was the Blind Spot monitor introduced? Some sources say 2011 and some say 2013?
This gen ML has lots of electrical gremlins, but a lot of them could be traced back to the rear sam due to a leaky taillight gasket. I replaced mine and solved 90% of my electrical faults.
The transmission is mechanically robust, but the conductor plate (speeds sensors) is susceptible to failure, guess it can be done with jackstands in a garage, it'll be messy though and condo's can get pretty upset if you leave oil marks on the floor.
Not all ML's have air suspension, google Mercedes VIN lookup, it'll tell you what the vehicle has in terms of options from the factory, but at 10+ years old if it's not currently leaking when you get it don't get upset that it does eventually, my 07 doesn't leak, but the struts are dead and non oem/rebuilt struts get mixed reviews, new oem bilsteins aren't cheap.
Can't comment on the balance shaft, manifold issues, my PS rack was replaced before I got it so not sure what the problem was.
Avoid diesel, aka Bluetec, powertrains, seek gasoline powertrains.
Avoid the balance shaft engine M272 V6.
Be aware of tumble flap concerns in the intake manifold of some engines.
Note the rear taillamp gasket situation as noted above.
With a growing family ("growing" means you have young children at home to me and, having raised two children, this to me means plenty of increasing expense for you), a 12 year old, complex vehicle with multiple well-known reliability concerns doesn't seem the best vehicle for a person in your situation. From my perspective.
https://mbworld.org/forums/market/765033
This has been bulletproof with the exception of having to replace the transfer case chain...started off as a $6500 repair, and I ended up doing it myself for about $125.
Henry
From what I understand there is a 2006-2007 ML500 which has the older engine. The 2008+ have the ML550 which is the newer style engine with possible bearing shaft issues?
I might test out a few of these and wondering if there is some cheap MB scan tool I can use which can diagnose all the systems like Engine, Transmission, Differentials and tell me if anything major is at fault? Most of these I looked at got oil leaks at the bottom of the front end, are these most likely a PS leak or do the engines have bad gaskets which causes leaks in the oil pan gasket+rear main seal?
Leaking oil is a red flag in my view. Avoid vehicles with oil leaks, regardless of where the oil is coming from, unless you are willing and able to address them.
A lot of people are doomed and confuse the bluetec engine with the cdi engine. IMO they are completely different in reliability.
I have an 08 GL 320 CDI with 206k and no engine or trans issues.
I also have an 08 ML 320 CDI with 141k and running great so far. I bought it 6 months ago.
I am also looking at buying another ML 320 CDI in pristine condition with the lowest miles so I have it 20 years from now when diesel vehicles will be nearly non existent.
I've had the following issues: Failed LED lights in both brake light assemblies (whole assembly must be replaced), and electronic ignition switch needed replacement. Both thankfully done under warranty. I've replaced front and rear airbags on suspension but this is just what it is if you want the airbag suspension. Otherwise all good.
I'd avoid the diesel V6 like the plague based on what I have read. Make sure the automatic has been regularly serviced as well. If you can stretch for a 550, do it. It's a better car all round with a brilliant engine that you'll love.
