HArd start on ML350 bluetec
Old Oct 28, 2019 | 07:28 PM
badassloumd's Avatar
ML 350 Bluetec
Hi. I am the sad / proud owner of an ML350 bluetec. I have
done a tone of work to this car in the past, (including 30+ hours
to replace the oil cooler seals) so I am not a total novice.. but
this one is driving me crazy.
The car has started to get very hard to start in the morning.
it takes 2 or 3 tries where the engine cranks for 10+ seconds
and will not start, then eventually dose. When it is running, it
runs as normal. Once warm the hard start issue is almost gone,
but not totally -- to me this rules out glow plugs. I have no fuel
leaks, and I have maintained it with filters (oil and fuel etc) very well.
The crank speed is "normal" and the battery is about 4 years
old. The car says in a garage that does not go below 50F.
I have the ICARSOFT scan tool (marginal, but way better
than nothing). It pulls codes, but I cannot translate them into
anything meaningful.
here is the code list:
111b00
130f00
16f600
16f700
P20BD
P20E8
P20BD
None of these code are in the Icarsoft data base, so if anyone
could help translate them from hex to "real life" I wold really
appreciate it.
Thanks!!
---Lou
Old Oct 29, 2019 | 05:14 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Please UPDATE YOUR PROFILE in USER CP to include the year and where you live.
Old Oct 29, 2019 | 05:30 AM
Try this procedure. With a cold eng. turn the key to pos. #2, no starting. Wait 10 secs. and turn the key to start.
Old Oct 29, 2019 | 07:25 PM
Towmater's Avatar
Ml350 bluetec
Also, does it try to start, then fails requiring you to try to start it again? How many times until successful? Temp outside?
Old Oct 30, 2019 | 05:22 AM
What were the results of the test?
I do not understand what you have written above.
