06 ML 500 Rear SAM Failure? Liftgate & radio
Old Nov 4, 2019 | 04:42 PM
CVR TX's Avatar
06 ML 500, 03 S 430
Hello. My 06 ML500 has two issues: a)the lift gate opens every time the driver's door opens, and doesn't close without a manual close, and even then doesn't always latch and b)there is a 5-10 minute delay for the radio to play once the car is on. The screen is on, though slightly dimmed, and no sound. It is the same regardless of radio/sat/cd. After a bit, it turns on. Are these two related possibly to rear SAM failure? Thanks in advance.
Old Nov 4, 2019 | 05:21 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Yes it probably is the rear SAM but only because of water entry into the spare tire area, which is caused by faulty tail lamp seals.
Remove everything in the spare tire area where the SAM, Tailgate Closing Module, and tailgate pump live.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 11, 2020 | 05:23 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
Hi, did you ever figure out what was wrong?
