ML350 stuck in park
If the eng. starts, turn off eng., step on the brake & turn the key to position #2. Then try to move gear shift into NEUTRAL.
engine will start if I reset the codes from the transmission, however, the codes come back and the red warning on dash returns as soon as I try to take out of park.
ill check this fuse just in case.
thanks,
The Auxiliary Battery allows the driver to position the shifter to NEUTRAL when there is a problem such as yours.
Access the Aux. Battery and test the voltage with a DVOM. Anything under 10 volts you must replace the Aux. Battery.
So if the Aux. Battery is faulty, replacing it is the only way you can have it towed to a dealer.
so back to my original question, is there a way to select neutral by accessing the selector on the side of the transmission?
