Rear suspension makeover torque specs
Old Nov 27, 2019 | 01:18 PM
capitanoMB's Avatar
2008 CLK550 conv, 2009 ML350, 2020 GLE450
Hello and Happy Thanksgiving!
My holiday project is rear suspension makeover on MY2009 W164 ML350 (136K miles) with steel suspension.
I have new shocks, springs, ball joints, control arms and all wishbone bushings, sway bar, links but I cannot find remove and install procedures with torque specs on forum.
Can anyone please upload few PDFs to help me out with the project ?
Old Dec 7, 2019 | 04:10 PM
capitanoMB's Avatar
All done
Thanks for help y'all!
Old May 21, 2020 | 04:47 PM
sirhc.c's Avatar
2022 X253 GLC 300 Silver
Originally Posted by capitanoMB
All done
Where is the thread? I need the specs.
Old May 22, 2020 | 06:35 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Please UPDATE YOUR PROFILE to indicate the year of your ML and whether it is gas or diesel.
Old May 22, 2020 | 06:36 AM
What rear end parts are you referring to?
Old May 30, 2020 | 05:34 PM
sirhc.c's Avatar
Sorry, I hadn't received any notification that there were other messages.
Updated.
Major, I replaced my rear shocks last week and was looking for the specs.
I used the same nuts that came off the original struts that had an original paint mark, and tried to hope that the thread pattern started in the same place. :-)
But I'm still interested in finding the correct torque specs as I will be doing most of the repair items myself. Replaced the front brake pads the week prior to the shocks.
Old May 31, 2020 | 03:28 AM
Regular shocks or do you have Airmatic?
Old May 31, 2020 | 05:05 PM
sirhc.c's Avatar
My unit has regular single struts, no airmatic.
Old Jun 1, 2020 | 08:02 AM
M/B does not provide a PDF for the just the removal shock absorber but does provide one for the rear spring.
But that PDF does not show any torque values.
File Type: pdf
Old Jun 1, 2020 | 09:30 AM
sirhc.c's Avatar
Thanks Major,
I found a great YouTube video for the re and re. Got it done in record time, but they also didn't quote any specs.
I did the norm for the upper nuts, tight +1/4 turn, and the lower bolt I rattled on with an impact as that was the only way I could get it apart.
So far so good. All buttoned up.
I will keep looking through some of the other resources.
Appreciated.
Chris
Old Jan 11, 2026 | 01:03 PM
Jboog14's Avatar
Mercedes ml350 bluetec
Torque Specs
Can anyone answer the OP request. I’m looking for torque specs for the rear suspension as well. Just replaced rear springs shocks trailing control arms and knuckle. Also need axle nut specs as well. Have a w164 2011 ml350 bluetec. Much appreciated.
