So many oil leaks...
Old Jan 25, 2020 | 11:35 AM
turbodaemon's Avatar
2009 ML320 Bluetec
Hello fellow masochists who still own these cars,
My 2009 ML 320 Blutec leaks oil. Big surprise, I know.
I replaced the oil cooler seals. Turns out they were already the newer purple ones. That made no difference on the amount of oil lost.
I then replaced the gaskets between the oil filter and engine block. That seems to have made some difference - now I get about 300 miles per quart of oil, versus about 100 previously.
What should I replace next?
Old Jan 25, 2020 | 01:27 PM
utopify's Avatar
2007 ML500
Timing inspection cover? Valve covers? Dipstick tube? I replaced these on mine (albeit the v8 version).
Old Jan 25, 2020 | 09:35 PM
chassis's Avatar
2017 GLE350 4MATIC
If you are leaking as much oil as a 1 quart in 300 miles, the source of the leak should be obvious.
Pressure wash the engine, then watch carefully over time for leaks. With the high rate of leakage you posted, it should be quickly self evident where the oil is coming from.
Old Feb 18, 2020 | 04:48 PM
2009 ML320 Bluetec
The entire front of the engine is constantly soaked in oil from top to bottom. Serpentine belts keep melting. I am still not able to trace the leak to a single point. I hate this car with the burning passion of a thousand suns.
Old Feb 18, 2020 | 08:54 PM
chassis's Avatar
2017 GLE350 4MATIC
Have you pressure washed the engine? This will help you isolate the source. That much oil sounds like something is flowing from a pressurized or immersed/submerged source. Oil cooler in the engine vee?
Old Feb 19, 2020 | 04:48 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Chassis, what is "the engine vee"? Intake manifold?
Old Feb 19, 2020 | 07:04 AM
chassis's Avatar
2017 GLE350 4MATIC
Yes, the engine “V”, between the cylinder heads, often under the intake manifold. The OM642 engine has an oil cooler in this location, not sure if yours does. If you post your VIN one of us can look at the parts diagrams and provide more suggestions.
Old Feb 19, 2020 | 03:08 PM
I was just asking about what you meant so it can be clarified.
