ML 350 CV Boot Replacement, Or New Axle
Old Mar 8, 2020 | 08:55 PM
Paul91103's Avatar
2011 ML350 Bluetec diesel; 2018 Ford F250 PSD 6.7l; 2021 Honda Pilot
Angry ML 350 CV Boot Replacement, Or New Axle
While changing the front shock strut I nicked the CV boot. Though “small”, grease can come out. I tired a shade tree repair to get me by. Has anyone had experience with a more permanent fix, boot replacement, or will a new axle be in my future??
Left front axle, outer boot.
Thanks.
Old Mar 8, 2020 | 09:01 PM
chassis's Avatar
2017 GLE350 4MATIC
Try searching https://www.mercedesbenzstarparts.com for a boot kit. If you go the effort of installing a boot kit, I would make the small additional effort to replace the axle shaft entirely. Just my $0.02.
Old Mar 12, 2020 | 01:01 PM
Paul Adams's Avatar
ML 350
Wanted to provide a final update on this issue to help other owners. I was able to use SooGoo and a bicycle tire patch to plug the nick, allowing me to get to my shop for repairs. I am pleased to say that the temp patch worked sufficiently such that I lost no grease on the 20 minute freeway/street drive to my shop. One thing I learned was that the old school black rubber tire patches appear to be no longer used. All I could find at Walmart and Target are thin, green self-adhesive discs. I was skeptical as to if it would hold. Glad to say that the patch did hold, covered with the ShooGoo. I added a second layer of Shoo Goo with 24 hours between applications and final cure. I found this method of temp repair on YouTube.
My local shop was able to pull the axle and replace the boot without needing a new axle shaft.
Removal of the axle was attempted by me, with no joy. Tech indicated it was a job getting it out. I have. 2011 ML 350, driven in MN/WI since new. They used an air tool to get it out. I was using a hammer to no joy.
Glad to have an OEM boot back on.
I hope this helps others.
