P2458 Code need help
Old May 23, 2020 | 10:40 PM
Harinderassie's Avatar
2012 GL350 Bluetec
Good evening all,
I scanned my 2011 ML350 bluetec and i got an Code of P2458 Diesel particulate filter regeneration duration. So i would ilke to kow what part do i have to check or fix. I have cleared the code but after drivning about 25 km it the same code came back. What do i have to check to fix. I appreciate everyones help if some can point me in the right direction.
Old Jun 3, 2020 | 09:02 PM
2012 GL350 Bluetec
Ok an update so we flushed the DPF with Liqui moly DPF cleaner and purge and ran it for 1 hour at hight ways speed . The P2458 code is gone, but now i am getting a different code P2459 which does not go away. Please help how to fix this code now. No limp mode and have full power.
Old Jun 3, 2020 | 11:16 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
There are no "P" codes for CDI. The code reader you have make their own codes.
File Type: pdf
