Help with 2011 ML350 Bluetec... codes
I bought a 2011 ML350 Bluetec about 3 months ago with 88,000 miles. I have been fighting the check engine light coming on, yet the codes always show the mileage of occurrance in the 40K mile range. I have reset the codes, they keep coming back or new ones pop up, but they are ALWAYS from much lower mileage timeframes.
Oil Changed 88,200 to Mobil 1 ESP 0W30
Note: New main battery at about 89,000 miles in March, added 2.5 Gal of DEF
Mileage 6/4 92,200 miles
NOTE: I have had to add about 8 qts in 4000 miles (about 500 miles per Qt. Not good). No obvious smoke and no leaks. Its not in the cooling system either. I have read a lot about the OM642 engine issues.
Here's the history over the past few weeks. ML350 Fault Codes Read w/ Autel Maxi-Diag
Had the 111500 “The Regeneration Frequency of the DPF is not OK” code multiple times during this time, always showed mileage at time of occurrence in the 42+K range. Erased codes at that time.
5/20
Code 111500 “The Regeneration Frequency of the DPF is not OK”
Freq Ctr: 1
ODO (fault first occurred) 46708.0
ODO (fault last occurred) 46708.0
Code 6001 (stored) “The supply voltage of the control unit is too low”
erased codes
5/24
Freq Ctr: 1
ODO (fault first occurred) 46940.0
ODO (fault last occurred) 46940.0
erased codes
5/25 (about 200 miles into a 730 mile trip)
Freq Ctr: 1
ODO (fault first occurred) 47054.0
ODO (fault last occurred) 47054.0
erased codes
5/25 (about 500 miles into a 730 mile trip)
Code 16CE00 (stored) “The test of the AdBlue system has not been carried out frequesncy counter possible engine starts is active”
Code 111500 (Stored & Current) “The Regeneration Frequency of the DPF is not OK”
Code 106100 (Stored) “The upper limit value for long term adaptation of the SCR exhaust aftertreatment system was exceeded”
Freq Ctr: 2
ODO (fault first occurred) 47648.0
ODO (fault last occurred) 47682.0
erased codes
5/26
The driver display had a message like 16 Starts remaining on AdBlue. Didn't drive.
5/27
Picked up 2x2.5 Gal containers of DEF. Would only take about 4 Gals to fill (7 Gal capacity)
6/3
Code 16CF00 (stored) “The test of the AdBlue system has not been carried out. Frequency Ctr possible engine starts is active”
Freq Ctr: 2
ODO (fault first occurred) 47736.0
ODO (fault last occurred) 47778.0
Code 111500 (stored) “The Regeneration Frequency of the DPF is not OK”
Freq Ctr: 1
erased codes
6/4
Code 15FF00 (stored) “The lower limit of component B28/8 (Pressure Differential Sensor (DPF)) was dropped below/not reached”
Freq Ctr: 4
ODO (fault first occurred) 48490.0
ODO (fault last occurred) 48534.0
Thoughts, Guidance, Help????
If the old ones from lower mileages are just the added value you get from the scanner, then obviously don't worry about them. I'd actually like to get one of those if it gives that level of insight into the code history of the vehicle.
Anyways, so which of the codes are current issues?
BTW, that scanner does let you reset the oil indicator when you change oil too.
Oh...Forgot to mention, there are no driveability issues (yet) and I am getting 29-30 MPG on the highway.
I am thinking instead of a new DPF, maybe I should do a DPF/EGR/SCR delete? What is you opinion on that?
TIA, Bill
The second question, the answer is it is up to you.
Thanks,
Bill
Appreciate the quick help!
The bad news.... The AdBlue countdown has begun. Its currently at 15. Why? The DEF tank is near full.
Here are the codes:
106100: "Stored & Current" The upper limit value for long term adaptation of the SCR Exhaust aftertreatment system was exceeded.
15FF00 "stored & Current" The lower limit of component B28/8 (Pressure Differential Sensor (DPF)) was dropped below/not reached.
16CE00 "stored" The test of the AdBlue system has not been carried out. Frequency counter 'possible engine starts' is active.
16CF00 "stored & current" The test of the AdBlue system has not been carried out. Frequency counter 'possible engine starts' is active.
111500 "stored" The regeneration frequency of the diesel particulate filter is not OK.
Vehicle runs and drive with no noticeable symptoms.
OK.... So, will I be start limited???? it says "possible engine starts"
Any way to clear that?
Advice?
YMMV, read the comments for additional insight, not affiliated and all the regular yachty yack.
I would not trust the counter down to 0. Nothing stops it from jumping from 15 to 5. Don’t take that 700 mile ride in the truck until this is cleared or only if you don’t mind being stranded and towed into the closest dealer for a serious pounding.
Is there anyway to reset the counter with a scanner?
5/20
Freq Ctr: 1
erased codes
5/24
Freq Ctr: 1
erased codes
Freq Ctr: 1
erased codes
Freq Ctr: 2
erased codes
5/26
5/27
6/3
Freq Ctr: 2
Freq Ctr: 1
erased codes
6/4
Freq Ctr: 4
