2009 ML350 purchase w only 30,000 miles
Old Sep 20, 2020 | 04:43 PM
lws1's Avatar
E320CDI, ML350
Exclamation 2009 ML350 purchase w only 30,000 miles
I may be purchasing this 2009 ML350 with only 30,000 miles. It has resided in FL its entire life. It does not look like it was garaged. Is there anything in particular I should look for? The dealership is going to be going over it. The salesman sent me 3 photos that weren't very good, so I won't be able to tell if the rubber/plastic around the body is toast until I view it later in the week. I have only owned E-class. This will be a first for me if I decide to pull the trigger. It is one owner. Thought I would reach out to see if there's anything in particular I should look at. Thank you!
Old Sep 20, 2020 | 04:55 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
W164 350 gas and diesel veh. have a lot of eng. problems. You should bring a scanner with you and check for codes in all modules.
