Changed gas cap still getting error in cluster
06 Mercedes benz Ml500
Hey guys I have an 06 ml500 and I keep getting the check gas cap error in my cluster even after I changed the gas cap. Can someone point me in the right direction thank you
2002 ML 320 & 2006 ML500
Did you buy the cap from M/B?
If the cap replacement did not do the trick, then you must find a mechanic the has a smoke machine to see where the leak is in the fuel system.
