2011 ML350 SRS
Well, the problems came back again: ESP not working, check engine, random wipers in an off position, not able to shift gears, not able to connect scanner to the car(No system configuration information)…
The codes that I was able to scan right now are as follows:
C002; C001; D13A; C426;
C126; 105E00; 104000; 163D00;
105400; 105B00; 10BC00; 10BD00;
11CC00; 124900; 121A00; 5552;
5026; 5556; 5035; 7266;
7250; 91B6
As per first reply/suggestion by Maj. Dundee I have removed the steering column and checked for any damage or anything off but it all looks fine. Reinstalled it back, no change. Still unable to diagnose the problem.
Battery fully charged. Did a draw test just to make sure, no issues found.
Any ideas, please help?
7250; 91B6
24190Asz_ (11-01-2022)
My car is all fixed now. The problem was a short in a rear radar system in the rear bumper. When radars were changed, the wiring got stretched and corrosion shorted the system. The wires to radars were cut and waterproofed. I do not have the radar system anymore, but the car runs great. I also found a guy in Toronto that was able to erase the radar system from the main computer so there are no warning lights on the dash. Did a trip from Toronto to Florida and back and all was great.
what’s radar systems? Are those the bumper sensors?
what’s the error message on the dashboard? SRS malfunction or just SRS light?
please explain a bit to help others. Thank you
Radar system is a Blind Spot Assisst in the rear bumper.
For error messages please see the following: 2011 ML350 Bluetec dashboard error codes and drive to workshop warning - MBWorld.org Forums
There are pictures there with what was wrong.
Thank you Alex, my 2010 gl550 without Blindspot assistance.
but I got my problems fixed by cleaning the connector in the picture below. It was dipped in water by Rear SAM, but the Rear SAM is dry and good due to having the top cover.
Full of water under the SAM, water absorbed in inside the white foam ( sounds absorber?) in the picture.
2011 ML350 W164 Diesel
BlackML550 (12-28-2023)
Need a DR squib for a 2011 ML350 / W164. Anyone have one for sale?Call me, 908-4(two)nine, 9999. Thank you
I faced the same issues and your post was a lifesaver
I insulated the rear radar wires and everything became normal.
Thanks a lot!
Regards, Aka
Joshinator99 (02-14-2024)
