A/c help
Old Oct 16, 2020 | 09:08 PM
Randy Rodriguez's Avatar
ml350
A/c help
Ml350 2008.
wasnt cooling efficiently, and the electric fan had been running very high.
my researched pointed to the pressure sensor switch.
prior I checked the Freon and it seemed to by fine.
I replaced the switch,
evacuated the system and checked for leaks.
and it is perfect.
I fired it up turned on the ac
took the 1st charge with no issues,pressure was only at 30.
I connected the 2nd can the pressure shot up
to 70lbs red zone on my gauge..
I connected a 2nd gauge to confirm.
what I noticed is when the fan kicked on that’s when the pressure shot up.
the air is blowing hot, so it needs more charge.
any thoughts?
Old Oct 17, 2020 | 04:02 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
So you replaced the Pressure Sensor (not a switch) on your research and that didn't fix the problem.
The cooling fan will run at high speed once the A/C Control Module recognizes a problem, and will prevent the compressor to actuate.
What you should have done originally, was check for codes in the AC system.
File Type: pdf
Old Oct 17, 2020 | 12:51 PM
ml350
I did scan it there were no codes
Old Oct 17, 2020 | 01:08 PM
ml350
I did Scan it, There were no codes.
Old Oct 18, 2020 | 12:20 AM
Randy, if you only have a code reader, you will not be able to read codes in the AAC Cont. Module. The codes will be stored here.
Old Oct 18, 2020 | 05:31 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I would suggest you stop charging the AC based on pressure readings. The correct way is to do an evacuation and refilling by weight.
Good luck.
Old Oct 19, 2020 | 10:42 PM
ml350
Ahhh…. What is the procedure for doing that?
Old Oct 20, 2020 | 06:11 AM
You need a scanner type reader that will show codes in all and every 25 modules.
Amazon Amazon
