Air Suspension and Fuses
Hi,
New guy here. I have a 2011 first registered 2012 ML350 BlueTec AMG Sports and have had it for 6.5 years. I was lucky enough to get it with almost no K's on the dial.
I have two questions, the first being the engine bay fuse # 13 for the horn. The diagram shows a # 13A and #13B spaces perhaps for a triple(three leg as shown) 15amp fuse But only one 15 amp fuse is in place? The horn works but as I am nearly totally deaf maybe only one horn works? Why would they make a space for three fuse legs?
The second question is the Airmatic suspension. No matter where it is set, Comfort, sport or neutral the ride is HARD and I mean on rougher roads - HARD? The car will raise and lower ok but the ride is still hard on rougher surfaces. Not what you would expect from a Benz-OR is it?
Hope someone can assist
Cheers,
Graham
Cheers,
Graham
2002 ML 320 & 2006 ML500
Both horns are activated by relay KF, so if one horn works, the other one should too,
Open the hood, and remove the connector to one of the horns and have someone blow the horn. Did the horn blow loudly or was it somewhat muted?
Then do the same for the other horn.
Horns and suspension issue
[QUOTE=Maj. Dundee;8187069]Both horns are activated by relay KF, so if one horn works, the other one should too,
[/QUOTEHi,
Thank you for that. Have tried that and yes both horns work BUT why is there provision for a "double" (three leg) fuse and why is the #13B fuse space vacant? A Mystery for sure....
In the meantime my Air Metic suspension still rides HARD and there is no leaks in the system?
[/QUOTEHi,
It wasn't being rude, it was sarcasm. You couldn't even follow simple instructions to update your profile.
Terry26 (02-03-2023)
