OM642 ML350 Timing chain change
Old Oct 29, 2020 | 04:51 AM
Talal Al Hadidi's Avatar
ML350 bluetec 2010. W164
A very good day to you
I need your help pls.
I need to change timing change in my Ml350 2010
vin 4JGBB2FB6AA593877
and will buy the timing chain kit on-line
so is the part no. A0009936376
or 0009936376
is it begins with A or not
or the same
and which Mark is better ; febi , swag or ina
thanks
Old Oct 29, 2020 | 07:09 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
So you want to replace the timing chain.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 29, 2020 | 09:01 AM
I need to know the right part no. and the better quality to buy it
a mechanic will replace it .
Old Oct 29, 2020 | 09:44 AM
Post your full vin# with no spaces.
Never mind the vin, I got it.
Old Oct 29, 2020 | 10:15 AM
or 0009936376
or the same
thanks
The number you posted is correct.
If you do a search on M/B you need the A. If you are searching elsewhere, 0009936376.
Old Oct 29, 2020 | 10:46 AM
thank you Sir for your kind reply
before one year the chain was making strange noise , my mechanic remove the chain tensioner it was breaks into pieces, he said that the chain stretched, so he reassembled the tensioner and put a long no. 10 bolt into it to adjust the chain correctly, the engine works fine
now I'm afraid of driving the car because of the chain May cut , so I decide to change the timing chain kit
thanks for you continuous support , you urge me always especially I'm living in Iraq in which there is no qualified shop to support
thank you very much
Old Oct 29, 2020 | 11:32 AM
thank you very much
Thank you so much
I'm greatful to you
