W164 Airmatic uneven stance
I had the rear bladders replaced last week. When the car is switched off it lowers itself with the right side much lower that the left. While engine is running and car in raised mode the rear right side is 35mm lower than the left while at the front the left side is 5mm lower than the right.
While the car is in the lowers mode the right rear is 24mm lower than the left while the front is level.
Can it be a calibration problem and if so how do I recalibrate it?
Thank you
Thank you
E55Greasemonkey (12-23-2020)
Hi Mr Dundee
Not such a great answer.
I know they are responsible and they will most surely rectify the problem.
It is however an opportunity for myself to learn something and maybe be a bit wiser and gain some knowledge. This is the reason that I joined MBWorld.
Have a great festive season.
2002 ML 320 & 2006 ML500
So you want someone to tell you what went wrong when someone else did the repair.
