Pressure Control valve
Old Jan 3, 2021 | 01:43 PM
Talal Al Hadidi's Avatar
ML350 bluetec 2010. W164
my ML350 Bluetec 2010
vin
4JGBB2FB6AA593877
I need the part number of fuel rail pressure control valve
cause I have codes PO 087 & PO 088
and the work shop technician says that the valve which been installed is the wrong one as in the attached photo
thanks
Old Jan 5, 2021 | 04:11 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
According to your vin# this is the part #.
Old Jan 5, 2021 | 09:33 AM
thank you Sir for your kind reply
the part I need is the pressure control valve
not
the pressure sensor
thanks
Old Jan 5, 2021 | 02:12 PM
Here you go.
Old Jan 5, 2021 | 03:22 PM
Here you go.
Dear Sir
Thanks alot for your kind help , when I google this part no. it the part no. of the connector with 2 pins , the part no. of pressure control valve should be either
A 642 078 02 49
or
A 642 078 01 49
or another no. but same first 7 numbers
waiting your kind urge
accept my greetings
thanks
Old Jan 5, 2021 | 06:46 PM
You were the one that pointed to that part.
As you can see in the diagram there is no separate part and it seems it is part of the fuel distributor.
Old Jan 6, 2021 | 06:27 AM
thanks alot for you kindness
as the attached diagram and photo
thanks
Old Jan 6, 2021 | 06:48 AM
M/B does not show that part # and you said earlier that you were told it was the wrong part.
Old Jan 6, 2021 | 07:27 AM
the engine turned off after 80 km/h several times
the technician said because of the fuel rail pressure control valve
mine was with part no. A 642 078 02 49
I didn't find the same no.
I found A 642 078 01 49
when install it the engine turned off at 40 km/h
so they clean the old valve with some sepry cleaned and the engine work fine
I went to Bosch dealer in Irbil - Iraq he said that the installed part is not the original part no. for this engine but he couldn't give me the right P. No.
Old Jan 6, 2021 | 09:43 AM
Is that bottom fuel rail connected to the high pressure pump?
Old Jan 6, 2021 | 10:05 AM
Yes sir
Old Jan 6, 2021 | 01:11 PM
This problem is all caused by M/B. Instead of showing the part# at the end of the left fuel rail, they included it at the high pressure pump.
According to your vin# this is the part you need.
Old Jan 6, 2021 | 11:50 PM
Dear Sir
A very good day to you
I google this p.no. found it's called fuel pressure regulator as pi pointed in yellow in the attached photo , so I understood that I have to change this part A 6420740284 not the pressure control valve A 6420780249
is this right ??
Thanks and have great day
Old Jan 7, 2021 | 01:35 AM
Originally Posted by Talal Al Hadidi
Dear Sir
is this right ??
Today I removed this regulator found one of its side hole Clogged with something like mud
cleaned with sepry cleaner
hope this will fix the issue
thanks
Old Jan 7, 2021 | 08:13 AM
Don't you see that the part # I pointed to is called a VALVE?
Old Jan 7, 2021 | 11:17 PM
Yes Sir
it is
you see I became confused
here in Iraq there are no qualified workshop to deal with modern diagonal techniques
so I'm all ways get the right advise from you
thanks and have great week end 😊
Old Nov 5, 2024 | 02:18 PM
Deling's Avatar
W211 320
Guys do You know what torque is for this screw ?
thanks for any help
