Rear hatch won’t open
Old Jan 20, 2021 | 08:33 AM
Jxp's Avatar
Jxp
Ml350 Blu tec
Help! I own a 2011 ML. The rear hatch would not open using the key fob or the controller in the side of the driver door. You could hear it trying to open or close, but it would not open or close. There was nothing stuck inside the door. Recently it will not even try to open or close. In addition the interior light stays on while driving the vehicle, because the hatch seems to appear that it’s open. We tried to go through the back seats, removing the Cap on the lever and opening the door manually, to no avail.
does anyone have suggestions of what I can do next? I’m hoping that if I at least got the back hatch open I could try to reset it. any help is appreciated, thank you in advance!
Old Jan 20, 2021 | 11:13 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
When you try to open it with the Key fob, do you try lifting the door with the outside handle?
Did it rain heavily recently?
Old Jan 20, 2021 | 11:56 AM
Jxp's Avatar
Jxp
Ml350 Blu tec
I tried to use the key fob and the door switch , but no luck! It’s been very dry in south Florida!
Old Jan 21, 2021 | 01:22 AM
Use the key fob to open all doors, then crawl into the cargo area and remove fuse #40. Then see if you can forcibly open the tailgate using the outside door handle.
Old Jan 22, 2021 | 12:36 PM
Jxp's Avatar
Jxp
Ml350 Blu tec
Rear hatch
just tried pulling fuse #40 and tried pulling up on the outside black handle and no luck!! Still stuck closed!!
Old Jan 22, 2021 | 12:56 PM
What outside black handle?
Old Jan 22, 2021 | 03:00 PM
Jxp's Avatar
Jxp
Ml350 Blu tec
the black plastic piece under the chrome trim on hatch , it’s really not a handle. But I believe if you press in on it the hatch would open, when it works correctly!
Old Jan 23, 2021 | 03:43 AM
Tsumi's Avatar
2006 R500
There is an emergency release on the inside of the tailgate. See if you can use that to pop it open. If that works, you probably need to replace the lock actuator/mechanism.
Old Jan 23, 2021 | 05:06 AM
It most certainly is.
Old Feb 8, 2021 | 05:02 PM
Jxp's Avatar
Jxp
Ml350 Blu tec
I still can’t get in the trunk! The emergency latch inside the center of the hatch will not do anything!!
Old Feb 9, 2021 | 04:31 AM
Have you used this procedure?
Old Feb 9, 2021 | 08:08 AM
Jxp's Avatar
Jxp
Ml350 Blu tec
Rear hatch stuck closed
Yes I did see this you tube on this, this is exactly what my ML is doing , but the emergency release on the GL in the video works and it’s a different style than what’s on my ML, I am at wits end!! I am going to go to an Indi shop here in Ft Myers area! I really appreciate all the help on this form, especially Maj .Dundee!! Thanks again!
Old Feb 9, 2021 | 10:43 AM
Any time.
Old Oct 18, 2021 | 06:06 PM
Antkass's Avatar
GL 450
https://www.youtube.com/watch?v=iZ2N0MHasYo
what year is that GL450? Mine doesnt have that small black lever/button on the inside door panel.. Im having the same issue smh. Whats the name of that part he installed in the video?
