W164 ML550 Oil Volume/Amount
as an aside, I will be doing my own oil consumption level check post change, and I did not see anything from a prior post about if it was ok or even what others have recommended for a higher weight. I live in Nw burbs of Chicago, (someone brought up weather brings lower weight demand) so I will buy this time a 5w-30 to see if this helps the amount being burnt during highway driving.
thanks- Steve
thanks- Steve
You want a 5w-40 or maybe a 15w-40 depending on your climate.
A 0w-40 is always a great choice. Oddly it's very similar to the Euro 5w-30 visc-wise, just a hair thicker on the other side of the "40" line. 5w-40 is fine too, but is generally an older formula as a Euro oil, a truck 5w-40 HD diesel oil is actually a better choice.
Often people use plain old 5w-30 Mobil 1, even with a turbo, and it works fine. We dont' really heat up the oil in American driving, but the Euro spec has a buffer of being thicker for hours of Autobahn driving. You can get low wear with thick or thin oils, but too thick will kill MPG and power, and bad in cold w/short trip driving. On the other hand thick oil will be a bit quieter. The rule is to use the thinnest lube that doesnt' cause excess wear. Often American 5w-30 is fine in this regard, but you want a little "buffer" as well.
In the non-Di 3.5, I see no reason a good 10w-40 at 6000 miles is perfect down to +10F or so. Maxlife comes to mind. In 0w-40, Edge with titanium is king...
Don’t you just love questions here that can be answered by reading the owners manual? Manuals are available online, btw ... just like this forum.
Just for fun ... during the life of the 164, the spec for Om642 (diesel) changed from 229.51 to 229.52, including retroactively. This means from 5W-40 to 5W-30. 229.51 is superseded The top number is very much more related to engine design clearances than to ambient operating temperature ... the latter again virtually irrelevant given synthetics.
Speaking of Autobahn driving, a Mercedes cooling system can handle that and consequently so can the motor oil.
Just for fun ... during the life of the X164, the spec for Om642 (diesel) changed from 229.51 to 229.52, including retroactively. This means from 5W-40 to 5W-30. 229.51 is superseded The top number is very much more related to engine design clearances than to ambient operating temperature ... the latter again virtually irrelevant given synthetics.
The Winter test is conducted with a micro rotary viscometer, a MRV test at sequentially lower temps for 10, 5 and 0 ratings at -20F, -25F and -30F I think 6000cst is the goal.
I am befuddled by some of the criteria people list for oil properties. Just remember, a 5w-20 is thinner in cold than a 5w-30 and thinner than a 5w-40, for instance. Not all 5w oils are the same in cold.
A 0w-40, 5w-40, 10w-40, 15w-40 are all approximately the same 14-15cSt when heated to operating temp of +100C. The w is an indication of how much the oil thickens when cold. So if ambient is warm, a 15w-40 is ideal, in cold a 0w-40 is ideal. The difference being the 15w-40 is more robust and less volatile, so it won't burn....if that's what the issue is.
Different oiil's visc will overlap with other grades at different temps, making them more similar than people think. The only real difference is on cold start, then when fully heated. It works on both ends; a 5w-20 is the same as 5w-30 just a few degrees difference. I'll post some data later.
Also, there's no requirement for 229.5 that makes it special....it's really just a long-life spec for running extended oil changes. If you use regular oil and change it at 5000miles, not only is it ok the computer has a setting for regular or 229.5 oil. Frankly, non turbos can run on ANY OIL IN THE STORE. Bear in mind I mean xtra thick oil for hot climates, extra thin oil for cold....synth for extended changes.....ANY oil. Above the arctic circle, use 0w-20, in Saudi Arabia, 15w-40 or a 50 weight.
imo Mercedes should be more specific than jst "5w-30" or "0w-30" in the manual. API 5w-is quite different than Euro 5w-30. Most people run 5w-40 which is 14+cSt at op temp, API 30 weight is only 10cSt, quite a difference. Euro 5w-30 is about 12.5cSt
