2006 ML500 Rear Spring Replacement
Old Mar 10, 2021 | 02:14 AM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi,
As the OEM springs are 3 times the Aftermarket, is it advisable to go with the latter? The rear left spring has a large crack that can snap anytime. Does the new spring have to be purchased with all the top and bottom connecting pieces or the old ones can be reused?
Any removal/installation procedure will be much appreciated.
Thanks,
Old Mar 10, 2021 | 07:18 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
First you have to determine if there is a PINK or WHITE marking on it, diff. part #s.
As for the other parts, look at it this way, being that the spring is broken, wouldn't you want those parts on hand instead of waiting a couple of days to get them?
If you want to buy an aftermarket spring, that is your call to make.
Look at the bottom of the PDF for the special tools that you need.
File Type: pdf
File Type: pdf
Old Mar 10, 2021 | 09:17 AM
anavabi's Avatar
Thank you
Old Mar 12, 2021 | 11:32 AM
anavabi's Avatar
I can only find compression tool for spring removal. The document calls for tensioning tool. What is the difference please.
Old Mar 13, 2021 | 02:41 AM
You have to find out where you can buy the kit.
Old Mar 13, 2021 | 03:08 AM
anavabi's Avatar
Old Mar 13, 2021 | 03:37 AM
Here is help.
Amazon Amazon
Old Mar 13, 2021 | 09:04 AM
anavabi's Avatar
Thanks.
OEM from Fcp costs around $3000!!
Old Mar 13, 2021 | 12:54 PM
What's Fcp and what costs $3000?
Old Mar 13, 2021 | 09:07 PM
anavabi's Avatar
[QUOTE=Maj. Dundee;8291432]What's Fcp and what costs $3000?
Fcp Europe is a parts store same as Pelican parts.
Old Mar 14, 2021 | 03:18 AM
You really don't believe that, right?
Old Mar 16, 2021 | 03:40 PM
anavabi's Avatar
Old Mar 16, 2021 | 07:47 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
Just because someone wrote you this nonsense does not mean you indeed should believe it. Unless of course this tool is gold plated or diamond dust painted.
Old Apr 15, 2021 | 06:50 PM
Taiter's Avatar
2008 W164, 2009;GMC Serra
Do you have any idea what spring compressor do I have to purchase to replace the rear springs on my 2008 ML320 W164. All of the ones that I have seen on Amazon do not specify W164.
jim
Old Apr 15, 2021 | 08:03 PM
anavabi's Avatar
jim
Please refer to post #7 above.
Old Sep 20, 2021 | 06:51 PM
anavabi's Avatar
Eventually I got some time at hand to tackle this job. However when I expose the coils, picture below, I don't see and color dabs or streaks, where should I look to see if they are white or pink.
